Budget (including currency): $1400
Country: USA
Games, programs or workloads that it will be used for: Blender, Minecraft, Roblox
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1080p
Hi all!
Thanks for your feedback on my previous post, it helped me optimize my build a lot. Also should I go for an RTX 3070 or stick with the extra VRAM from the RTX 3060 12Gb for Blender?
My friend also really needs a new monitor, however I am very well versed in the parts space and not in the monitor space. Specs @1080p 120Hz or more 24'' or more
3 builds
$1365 DDR5: https://pcpartpicker.com/list/jDTxrv (Uses all the budget, also can go for RTX 3070) No budget left for monitor
$1183 DDR5: https://pcpartpicker.com/list/6Rbzyg (220 bucks monitor budget)
What are your thoughts on both builds?
Thanks!
https://linustechtips.com/topic/1526135-build-feedback-blender-build/
