i've been having some issues with HDR and can't figure out what the problem is. using madVR + potplayer + windows 11 + QN90A. i've always had HDR in windows display settings turned off. when i played a HDR movie my display would "switch" to HDR mode. i could always tell when this happens cause the display would turn black for a second. another way i could tell was by pressing control J in potplayer. it would say NV HDR. lately movies have been looking dull and washed out. i noticed it's not switching to HDR cause the screen doesn't go black when i start a movie. so i went in to windows display settings and turned on HDR manually. it does look better but still doesn't seem right. when i control J it doesn't say NV HDR, it says OS HDR. i've never seen this before and i'm assuming this is basically fake HDR similar to auto HDR for SDR content. since the screen isn't going black when the movie starts i'm pretty sure something isn't right but can't figure out what.
https://linustechtips.com/topic/1526077-hdr-problem/
Not sure when this happened, but I am also using MadVR + MPC-HC for HDR movies and for a long time I did not have to enable HDR manually either but idk, half a year ago, that changed. So, I think you're good when enabling it manually. At least it works perfectly for me manually. Have you set MadVR to transfer HDR meta data to display?
GAMER
SPEC: HYTE Y60 White/Black + Custom ColdZero ventilation sidepanel – AMD Ryzen 7 9800X3D + ASUS ROG RYUJIN III 360 – G.SKILL Trident Z5 Neo RGB DDR5-6000 64GB CL30-40-40-96 – ASUS RTX ROG ASTRAL 5080 OC – ASUS ROG STRIX B850-E GAMING Wi-Fi – Samsung EVO Plus 1TB, Samsung EVO Plus 1TB – Corsair HX1200i
GEAR: Samsung Odyssey Neo G9 G95NC 57" – ASUS ROG Harpe Ace Aim Lab Edition Wireless – ASUS ROG Claymore II Wireless –
ASUS ROG Sheath BLK LTD – FiiO K7 DAC/AMP + Beyerdynamic DT 770 PRO X (Limited Editon), Edifier S351DB, Steelseries Arctis Nova Pro Wireless
Home LAB
SPEC: Corsair 4000D Airflow TG – AMD Ryzen Threadripper 1950X – Corsair Vengeance LPX 128GB (CMK32GX4M2D3000C16 x4) – ASUS GeForce GT710 1GB – ASUS ROG Zenith Extreme – ROG AREION 10Gbps – Toshiba XG6 1TB, WD 256GB, Kioxia 256GB – Corsair HX750
GEAR: Philips 346B1C 34" – Logitech MX Keys – Logitech M705 – Jabra Evolve2 75
Racing SIM
GEAR: Sim-Lab GT1 EVO Sim Racing Cockpit + Integrated Vario Triple mount – Svive Racing D1 Seat – MSI 325CQRXF 32" x3 – Simagic Alpha Mini + Simagic GT4 (Dual Clutch) – CSL Elite Pedals V2 – Logitech K400 Plus
https://linustechtips.com/topic/1526077-hdr-problem/#findComment-16080790
i do have transer meta data enabled. also not sure when it started acting up. for a good minute i stopped using madVR cause i noticed potplayer has madshi as a renderer without installing madVR. i also noticed the HDR button at the bottom of the player so i assumed it was now built in to potplayer. i later started to suspect it was not really HDR but more like windows fake auto HDR. switched back to madVR and hasn't been working right since. during the time i wasn't using madVR i started using windows 11. not sure if windows is the problem or something else.
https://linustechtips.com/topic/1526077-hdr-problem/#findComment-16080814
I understand. Well, I have bought Smooth Video Project. Via the SVP installer, I simply choose to install the default stuff which includes MPC-HC + MadVR, then after I go into MPC-HC settings, set MadVR as renderer + HDR metadata to display, and it just works - and it works on both my monitors. Maybe try MPC-HC + MadVR?
GAMER
Home LAB
Racing SIM
https://linustechtips.com/topic/1526077-hdr-problem/#findComment-16080826
