Hello guys,
I recently upgraded my PC, following are the specs:
CPU: Ryzen 5 7600
Motherboard: Gigabyte B650M BS3H
RAM: GSkill 16x2GB @ 6000Mhz CL36
SSD: XPG s70 Blade 1TB
GPU: Gigabyte GTX 950
PSU: Silverstone 500W 80 Plus
The issue I am facing is that I hear a very light static sound (buzzing sound) in my headphone when plugged into my PC (motherboard audio jacks).
This didn't happen on my old PC. I don't think it is a grounding problem, because my headphone make no noise when the PC is off.
The buzzing sound starts when I login into Windows, and as my startup apps load it starts randomly during that period.
My Windows is up to date.
I tried cleaning the power outlet and the cables plugged into it in case of any settled carbon.
I also have a laptop, I drive the headphone I don't have any issues there.
Very weird and confusing.
Really appreciate any help.
https://linustechtips.com/topic/1524733-constant-static-in-headphone/
24 minutes ago, Mingus Muncher said:
Have you tried any other audio devices with your computer?
5 minutes ago, L4G_NAToR said:
Yes, I did try with my earphones, static does exist. 😞
I believe Mingus meant another soundcard or amp&dac, not other headphones, but OK.
Do the headphones use a 4-pole TRRS jack? Or a 3-pole (no microphone)?
Have you checked for residual voltage on the grounding pin(s) on your wall socket or extension cord?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Just now, Mingus Muncher said:
i mean other speakers besides your headphones
Yes, I have a headphone, earphones and speakers...
Red audio I plug my mic, green is for my headphone & blue is for the speaker output.
Static can be heard in both green & blue ports, it is very mild though.
Configuration for the green port is set to `Headphone` in the audio console and for the blue port it is `Front speaker out`.
This is what I had set on my old PC as well.
Understood, no I do not have any sound card/amp/DAC.
My headphone has a 4 pole, I use a Y splitter to connect to my PC.
I use Corsair HS50 pro headset.
6 minutes ago, L4G_NAToR said:
@191x7
How to check the following: Have you checked for residual voltage on the grounding pin(s) on your wall socket or extension cord?
You can use a voltage detector, a voltmeter, or a multimeter, or hire an electrician (to check your grounding).
My grounding is in place because the same power outlet I use for my laptop and old PC is also on the same outlet. I am not facing this issue with those.
UPDATE:
I think the static noise has something to do with audio drivers, I have noticed that it stops randomly.
I do not hear the noise when in BIOS.
My guess is that this started happening after I installed audio drivers from https://www.gigabyte.com/Motherboard/B650M-DS3H-rev-1x/support#support-dl-driver
How do I uninstall these drivers? From the device manager?
Do let me know.
