Hi guys,
Just thought I'd check in here first before stripping things down and draining my loop.
Came home to disgruntled girlfriend who reported the PC had been crashing frequently whist playing a game.
Windows management console reported a number of Nvidia driver crashes so that was my first port of call.
Double checked Afterburner was at stock (no OC) and same crash straight after loading a game.
2 reboots later and the PC failed to reach Windows with the below Pic of my screen straight after the BIOS Splash screen. 9 Blue dots in the bottom left corner. Eek!
I'm thinking its a gonner!
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1524151-possible-dead-3080ti/
2 minutes ago, Sawa Takahashi said:
Since you got an intel CPU, did you try booting with the iGPU instead ? It is possible that your Windows seitched to iGPU since the GPU crashed too many times ?
Yeh, thought about that but MSI in their infinite wisdom decided to leave out an HDMI or DP port on their MSI MEG Z390 Ace!
The PC isn't crashing as numlock and scroll lock respond with the keyboard light switching on and off. Mobo temp leds are also working as they should. After whizzing through the various codes, a successful boot shows CPU temp which it does.
I'm pretty sure the PC is booting correctly to the Windows login screen, just no display as the GPU is dying the moment Windows starts to boot.
I just tried plugging the PC into another screen (this time with DP) and same. Screen goes blank the moment the BIOS splash screen vanishes.
https://linustechtips.com/topic/1524151-possible-dead-3080ti/#findComment-16064895
Well, if your monitor is plugged into your GPU and your BIOS is putting out a splash screen, then your GPU is alive.
I suspect that your Windows got corrupted because of the many crashes.
You can boot on a USB stick and see if you get passed the BIOS splash screen. A USB Windows installer or a Ubuntu live USB should do the trick.
Good luck !
https://linustechtips.com/topic/1524151-possible-dead-3080ti/#findComment-16064901
Good luck !
Negative on that one.
Literally, the moment the BIOS splash screen vanishes, the screen goes blank.
Just tried to boot from Windows USB media and didn't even get to the installation screen.
Every so often, I do manage to boot to a desktop but the second I load the GPU, black screen.
https://linustechtips.com/topic/1524151-possible-dead-3080ti/#findComment-16064952
