Budget (including currency): 360$
Country: Somalia
Games, programs or workloads that it will be used for: Gaming/Programming
I had that build
https://pcpartpicker.com/user/abdo-totti/saved/MY6dnQ
But a rat ripped off the PSU And case wires, and the GPU is dead too, so I decided to buy a new PSU and a case. I got a Corsair Tx Bronze Certified 650 Watt and an ATX case, but the Motherboard lights are on, but the PSU fan only spins for 1 sec, and it stops. I think it's the motherboard, ram, or CPU because I tried to jumpstart the PSU alone, and the fan is spinning.
Is there any way to know if the Motherboard, Ram, or CPU is officially the issue, or do I have to swap everything and go into new stuff, which is much saver?
So I want to know Which motherboard/ram/CPU I should buy with that budget, including 35$ per kg shipping.
PS: Sorry for the bad English.
https://linustechtips.com/topic/1523198-help-with-this-build/
