Hey guys , I really need to ask this question . I need help with one watercooling for my pc .
This would be my build : I7 4770k 3.5ghz , zalman z11 plus , asrock z87 pro4 , corsair 650w , asus geforce gtx770 oc directcu 2gb , kingston 2400mhz 2x8gb RAM , seagate barracuda 7200rpm 1tb sata 3 . What's the best cooler for this setup? Corsair WC Hydro Series H55 is ok for it? I can't get any more expensive than 80€ :/ If someone can help me please add me on skype (dramazexe) or PM me .
https://linustechtips.com/topic/152300-help-me-please/
I ask for a move for this thread if I understand it right (move for the watercooling section).
scratch that top one was typing while reading.
I don't advice on the h55 for corsair I may like the h100i and the h110 but for the money I doubt the h55 is a good performer I've only used that aio 3 times and I'm not very pleased with it. for the price to it's performance.
may I ask where do you live? and where do you plan to buy?
for similar price (basing it on amazon us) some noctua are actually much better performer and with a cheaper price.
Live your life like a dream.
https://linustechtips.com/topic/152300-help-me-please/#findComment-2034470
go for the corsair h100i or h105, both are good aio coolers to cool overclocked cpu's
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/152300-help-me-please/#findComment-2034491
May I ask why you're going to a 4770k instead of a 4670k?
As well as 2400mhz ram?
and no ssd?
As for your question, an nh-d14 would work in most cases.
edit: the nh-d14 would fit, just checked.
Woo!
https://linustechtips.com/topic/152300-help-me-please/#findComment-2034512
I'm not overclocking the PC , I live in Portugal and I'm thinking in get every part from pcdiga.com , portuguese store.
I'm getting a 4770k instead of a 4670k and 2400mhz of ram cuz I want a nice desktop to render , I know it's not the "ultimate render pc" but I think that's ok :)
https://linustechtips.com/topic/152300-help-me-please/#findComment-2034568
What will you be rendering?
If you're not overclocking, a hyper 212 evo and an h81/b85 board should work.
Woo!
https://linustechtips.com/topic/152300-help-me-please/#findComment-2034678
It is for gaming too :x I'm ok with the parts , I only need the watercooler xD I really need one that's cheap and really nice :)
so what if its for gaming too ? if you don`t overclock don`t buy a K cpu because its money wasted. i7 4770 if you want integrated gpu if not xeon 1230 V3(its an i7 with 100mhz less and no igpu)
Edited by s3ns3
https://linustechtips.com/topic/152300-help-me-please/#findComment-2039008
I would not recommend the H55 because it has a very high problem rate with either leaks or pump failure. Try looking at the CM Seidon 120 m/v or a Thermaltake Water 3.0 if you can find it at a sub $80 price, it is just above that normally.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/152300-help-me-please/#findComment-2041218
Please help me :/
If you arnt overclocking, you can stick with the stock cooler, or the cooler master 212 EVO, as it will perform well but won't be nearly as loud as an AIO.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/152300-help-me-please/#findComment-2048572
