Hello.
     I'm wondering if anyone can help me with with any troubleshooting on latency from my home network. I've been noticing a small lag spike when watching videos on my pc and later when I was playing games with a buddy, I was getting a more noticeable effect. Playing Halo MCC and Infinite specifically I would see a message saying "packet loss" and when we would try and load a new level on MCC he would desync and then no longer be on the same game as me but on the same level. Just a few moments ago I decided to do some troubleshooting and well...
Problem;
     I have bad packet loss while keeping very good ping.
Troubleshooting Done So Far;
      As my system was newly built I checked my drivers by installing Armoury Crate and let them update it to keep it hassle free. No improvements when running ping tests.
     My router was using PFSense, checking and applying the update from 2.6.0 to 2.7.0. No improvement.
     Ran ping tests from PC to Router, no issue. PC to Google and Router to Google, same issue. Image Below.
Is there anything else on my side to help find out, if not fix, the issue or do I need to talk to my ISP to go any further?
Thank You in advance.
https://linustechtips.com/topic/1522947-latency-issue/
ISP.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1522947-latency-issue/#findComment-16056696
Are you connected to wifi or wired, what is your internet speed that you pay for from the ISP and what speed are you getting if you run a speed test what are the system components of your build, could be a faulty network adapter, your isp, or your network speed in general
https://linustechtips.com/topic/1522947-latency-issue/#findComment-16056772
