Budget (including currency):  ?????
Country: USA
Games, programs or workloads that it will be used for: may be used for ai coding as well as different rpgs
Other details:  i know it says no dream builds but that is what i am actually building. have been getting part for a few months now
monitors: https://www.microcenter.com/product/646643/lg-40wp95c-waus-397-5k2k-wuhd-(5120-x-2160)-72hz-ultrawide-curved-screen-monitor (Have)
https://www.microcenter.com/product/654048/lg-32uq85r-waus-315-4k-uhd-(3840-x-2160)-60hz-led-monitor (have)
keyboard mouse, mic and speakers have.
Power supply: seasonic 1600w (have)
case: O11 dynamic XL (have)
ram: 64 gb 6000 (have) - debating about changing out to  192GB
gpu: 4090 (need)
cpu: 13900k (have)
mobo : msi Godlike z790 (have, explain why later in post)
fans : li lie
cooling: ????
second comp: mac studio
i am building a new pc and am debating about just going full send as i already have so much spent on it. I got the monitors for work and want to add a gaming pc to the set up. the problem is in order to make sure everything, keyboard, mouse, sound and camera follows properly i need to use thunderbolt 4 from the 40 inch to the computers as it is the only way all 5 things will follow properly between the 2 computers. right now i have the mac studio hooked up via thunderbolt to the 40 inch and the 32 inch daisy chained to the 40 inch via usbc so i have the audio input from them and all 4 usb inputs between the 2 monitors running back to the computer via that one cable. in order to keep one keyboard and mouse hardwired to both computers i needed to be able to connect via thunderbolt and then just unplug and plug as their are no switches for thunderbolt. the problem is that their are very few mobos that support thunderbolt and even fewer that support thunderbolt AND are able to pass the GPU video and not the iGPU signal though. thus after only finding like 3 of them i settled on the godlike as i like the look the best . . . and so i can say my computer is godlike. (shrugs) now im debating im already spending this much on the computer should i just go all out and do a custom loop and max out my memory. i know the O11 dynamic xl is great for water cooling and the tubing would make the case look fuller and fill it out and then i can also maximize the cooling of the system either that or get a liquid cooled GPU but feel that will not look as good
https://linustechtips.com/topic/1522921-flex-ai-modeling-build/
To be honest i did not read your whole description but i do suggest you just get a dock that has thunderbolt 4 like the (Kensington SD5700T Thunderbolt 4 Docking Station – Best Thunderbolt 4 hub for TB4 ports), and in my opinion water cooling a pc is a nightmare and is not reliable so i suggest you go with a beefy AIO and maximum airflow for that i suggest the CORSAIR 7000D AIRFLOW (for a smaller footprint), or TUF Gaming GT502 PLUS (plenty airflow, but very big). (the o11 dynamic evo is a "better" option than the o11 dynamic) The AIO that I suggest is the iCUE H170i ELITE LCD XT Display Liquid CPU Cooler 420mm also if you care about "beautifying" your case you can just go all out and get the new fans from lian li and your build will look amazing, and depending on the color theme you go for i suggest you match your GPU and RAM to match the whole theme.( I am not a pro) (sorry that i couldn't be more help)
https://linustechtips.com/topic/1522921-flex-ai-modeling-build/#findComment-16056790
