Good Multipoint earbuds or headphones for work and play
The Jabra 75t earbuds are what I use at work. I have them linked to my desktop and my cell phone. You can't listen to both devices at the same time, but they are permanently paired to both (granted I have bluetooth enabled on both devices). That's the simplest answer I have for you, and in the event I want to force audio from one device or another, I just disable the bluetooth from the device I don't want audio coming through. No need to pair/repair aside from the first time.
As an added benefit, the Jabra 75t have active noise cancellation, and a noise passthrough mode. There's also an app that you can download to tweak the EQ of the earbuds to suit your listening preferences. (out of the box, they are a bit heavy on the bass but I don't mind that for most EDM, but prefer to lower the bass response when listening to death metal for example)
If you want the ability to listen from multiple devices at a time, you will want a physical audio mixer. (You can do this via software but it gets complicated, I prefer to have a physical mixer personally) The mixer that best suited my needs was the Mackie ProFX12v3. Depending on how many inputs you want, you could probably get away with a smaller variant with less inputs compared to the 12input I just listed.
