Smart devices overwhelmed router
Solved by PdxDad,
11 hours ago, Falcon1986 said:Since that router has dual 5GHz antennae, you can disable Smart Connect and run one at a wide channel width (higher speeds, shorter range) and the other at a narrower channel width (lower speeds, slightly longer range). That way, your non-IoT clients can probably still stay connected even at the other end of the house.
Tried this out last night and worked great. The combination of this and moving all no IoT off 2.4ghz seems to have helped. Id usually wake up in the morning and have to restart the router because the 2.4ghz would be offline.
