Inconsistent load on UPS with Gaming Computer
Go to solution Solved by BeefBrothBoi,
11 minutes ago, 191x7 said:
The mentioned system should be drawing between 400W and 450W from the UPS under load, add 35-60W for the monitor (for each monitor) and a few W for other peripherals.
Does the UPS not have an load indicator?
It does, it has a screen on the UPS that is confirming what HWinfo is saying that its only 54W. I am wondering if the 54W it is reading is just my two monitors and its not reading my PC at all. The manual does not saying anything about any outlets that are excluded from the load reading (which wouldnt make sense to begin with).
EDIT: I have figured it out, I have the outlets switched. I had my monitors plugged into the battery and the PC was just plugged into surge. I thought I had already checked this but obv didnt do a good enough job. Thank you for your help!
Hello,
I just recently built a gaming PC, I will post specs below. After about a month, my apartment building had a power surge and the motherboard/PSU stopped working. I replaced them and bought a UPS to protect my PC for the future. I originally bought a 600VA/300W UPS from APC and went back to gaming. When playing a normal game of Valhiem it started beeping and the software indicated it was due to exceeding the load on the unit (Said I was using +300W). I thought this was my mistake and that I had bought too small of a unit and replaced it with a 1500VA/900W UPS also from APC, but now I haven't seen the load go over 54W (using HWinfo64 to monitor).
Specs:
AMD Ryzen 7600X
ASUS TUF 4070Ti OC Edition
32 Gigs DDR5 6000 GSkill Ripjaws
ASUS Strix B650E-F Wifi
2x WD Black SSD's
Corsair RM850X PSU
Was my original assumption that the beeping was due to exceeding the output correct? Or was it due to my buildings power being wonky?
Any help is appreciated! Thank you so much!
Broth Boi
a 300W unit isnt gonna run your pc off battery either way, it'll just murder the battery trying to.
as for the load supposedly being only 54 watts, at idle maybe.. but while gaming that's just wrong.
Thank you, I will investigate why that may be the case. Even while running benchmarks (3D Mark Time Spy & RD2 Benchmark) it was only ever 54.
it's just not giving a decent reading then.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
been there, done that, and didnt think of that at all.
