Im going to repaste my cpu today. The paste currently applied was the included paste that came with my DRP4 but i figured i could do better by swapping out the ILM with a contact frame and applying some kryonaut. The paste has been on there since april when i built the thing so I dont think it should be too hard to get off with the 70% IPA i have. Im planning on using cotton balls and coffee filters to remove the existing paste. Is there anything I should know before going to repaste my cpu and cooler? This is my first time doing such a thing.
Edited by Sparver
https://linustechtips.com/topic/1519409-repasting-tips/
You dont swap out your IHS with the contact frame. You swap out ILM with the contact frame. Other than ILM swap, its just a thermal paste swap, no special procedure is needed.
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033382
Are you noticing high temps with your 13th gen?  The Dark Rock Pro 4 is a great cooler, and BeQuiet preapplies good paste.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033396
I have a 13600kf on an msi z790 tomahawk. The cpu is manually undervolted a tinge and i also used MSI’s liteload undervolting to lower it further (i cant remember the specific offsets right now). The temps sit around 40 degrees C with idling and light usage and climb as intended with heavier usage without overheating. Im mainly doing this just because I want to see just how much cooler i can get it to run. Also, the drp4 didn't have paste preapplied on it if thats what you meant in your post. It came in a tube with no markings or identifications and i essentially applied the whole tube on it.
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033415
Right, pre-applied or provided, sorry.
Well, love to see some before and after temp graphs if you do this.
To answer your question tho, nothing special about swapping paste.  I just use a paper towel to wipe it off when I do it. *shrug*
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033420
Thx. Im not smart enough to make a graph but i’ll report back here with the results
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033422
Here are the results. Please forgive the god-awful piccollage I made to present this but as you can see, there is an appreciable drop in temps with the contact frame and kryonaut.
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033668
Curious what drop to attribute to the contact frame and how much to the paste change, but either way it's significant.  Nice work.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1519409-repasting-tips/#findComment-16033693
