Hello so I just filled up my loop and I know there were bubbles that will gradually drain out and cause water levels to decrease. I do also have a vent valve over my fill hole in my distro block. Could this also be some form of an evaporative issue?
I did. leak test it and kept it running for 3 hours to see if I had any form of leak and there was no water on paper towels I left around the fittings.
is evaporation something to be expected because technically it is not closed off completely but instead has a vent valve to get rid of air pressure(I think?)
https://linustechtips.com/topic/1517969-water-level-decreasing/
Should always expect it to evaporate. But more so just more air slowly getting out of the loop.
https://linustechtips.com/topic/1517969-water-level-decreasing/#findComment-16023517
Was it a good idea to use the purge valve kind of fitting or to just close it off entirely?
I was worried about the pressure getting to be too much when it warms up, ya know?
https://linustechtips.com/topic/1517969-water-level-decreasing/#findComment-16023565
I do both. Depends on the rig and how longs its been together.  Doubt it will build enough to cause an issue though.
https://linustechtips.com/topic/1517969-water-level-decreasing/#findComment-16024225
nah don't need a purge valve, my 1 year old custom loop still works fine without it
if u see coolant level drop, u can always top it up... so far I only done once on my loop
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
https://linustechtips.com/topic/1517969-water-level-decreasing/#findComment-16024746
