Replace Bykski DDC pump with EKWB DDC pump?
OK, my Bykski DDC pump died a couple of weeks back (that was a bit of a horror scenario walking in to 100% fans and a 90°c CPU) so I was forced to replace it with EKWB bits.
The EKWB DDC 4.2 PWM pump and EK-DDC Heatsink fit onto the Bykski 7000D Distro plate perfectly without any problems whatsoever. You have to disassemble the PWM pump a little bit and apply the thermal pad + heatsink, but it's a simple task.
The EKWB DDC 4.2 PWM pump is a major upgrade over the Bykski I had. The Bykski DDC ran at 1800 RPM minimum and the impellor was off ballance, leading to it scraping on the inner housing of the pump - and therefore noisy. The new EKWB pump will run very low, probably around 900RPM, but I have it at 1200RPM and it seems to be delivering the same flow rate as the Bykski DDC at 1800RPM, except the EKWB is very quiet.
Also, not sure what could be causing this, but after the EKWB DDC pump was installed my rig is running and idling considerable cooler. Maybe I had a big air pocket in one of my rads, but in any case it was money well spent upgrading to EKWB.
Also, I don't think the EKWB DDC 4.2 PWM pump would ever fit in the Bykski DDC heatsink. The heights and internal elements / groves / notches seem completely different. Just get the EK-DDC Heatsink while you're at it, it's really heavy and clearly dissipating the pump's heat and probably soaking up a bit of vibration as well.
