RTX 4080 Power Cable
Go to solution Solved by GuiltySpark_,
56 minutes ago, red773 said:
would there be any issues with it powering my current 4080?
No
Hi I know this is a dumb question but it's one I couldn't find the answer to online. I currently run a 4080 using the out of the box 3x8 pin power adapter however I am about to purchase a custom cable kit from cablemod which makes a 12pin high power to 3 8 pin plugs that go directly into my AX1500i power supply. However I'm planning a monitor upgrade in the future that would warrant me to sell my card and upgrade to a 4090 instead, if I instead get the 12pin to 4 8 pin cable that is meant for a 4090 would there be any issues with it powering my current 4080?
Thank you I appreciate any feedback
https://linustechtips.com/topic/1517219-rtx-4080-power-cable/
No
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1517219-rtx-4080-power-cable/#findComment-16017551
Why not just get Corsairs own cable that connects directly to the PSU?
https://www.corsair.com/us/en/p/pc-components-accessories/cp-8920284/600w-pcie-5-0-12vhpwr-type-4-psu-power-cable-cp-8920284#overview
https://linustechtips.com/topic/1517219-rtx-4080-power-cable/#findComment-16017569
13 minutes ago, Alex Atkin UK said:
Sorry for the clarification the cablemod cables im buying also go directly from my gpu to my power supply.
https://linustechtips.com/topic/1517219-rtx-4080-power-cable/#findComment-16017579
