My specs
i5 11400f
B560 prime plus
Gtx 980 ti
2*8 gb ram
Ssd nvme m.2
Psu gigabyte b700h
My pc suddenly shut down then i tried changing the psu doesn't work then i put another gpu in my pc it worked but my gpu in my pc and another pc doesn't work if i put 8 pin connector (ps: the first time it powers on for a second and shut down then nothing until i shut down the psu and on again it powers for a second and shut down) and if i put 6 pin alone or doesn't put any connecters my pc works and monitor says ( power down your pc and connect the pcie to the gpu ) ... Is it a fixable problem or the gpu is dead
https://linustechtips.com/topic/1516949-gpu-8-pin-problem/
You either have a blown power stage or something related to power. Someone who knows what they are doing might be able to fix it but I wouldnt get my hopes up.
https://linustechtips.com/topic/1516949-gpu-8-pin-problem/#findComment-16015615
Thanx for the quick reply i wanna ask is it my psu that did this or it just happens with any psu so i can avoid the problem in the future
https://linustechtips.com/topic/1516949-gpu-8-pin-problem/#findComment-16015624
It depends on how many times you tried power cycling it since it died. Your GPU almost certainly had a VRM failure, and the more times you power cycle it the more likely you are to have killed the core at the same time. The vast majority of 980 Tis were poorly designed for VRM cooling, so unless you've got one of the handful of good ones it's probably not worth fixing as the rest of the VRM is likely pretty close to the end of its life and it would probably just die again.
https://linustechtips.com/topic/1516949-gpu-8-pin-problem/#findComment-16015627
It more than likely would've happened on any PSU, I'd still be fine using that PSU.
https://linustechtips.com/topic/1516949-gpu-8-pin-problem/#findComment-16015634
