The left half of each is as it should, the right half isn't connected all the way. I doubt it would cause an issue, they should theoretically naturally current balance themselves and not overheat and melt, but I wouldn't rely on that and you still should reseat them and get the connectors connected correctly.
https://linustechtips.com/topic/1516831-cpu-power-cables/#findComment-16014815
