Need help with radiator placement in a custom loop
Case looks to have bad airflow so id just swap it out to a better case that has airflow and also something thatll accomodate the loop
if you are considering custom loop for less noise or lower temp then swapping that seemingly no airflow solid front case will fix your issue
If its for aesthetics then do whatever as long as it doesnt end up performing worse than an aio
If you really wanna stick with that case then seems like the only sensible rad placement would be front cause bottom rad will problably be choked of any air and be effectively useless but if the area below the case has some breathing room then maybe itd make sense since the bottom rad wont be choked of air
And yes seems like both need to be intake
