so this has happened on an off, i go to turn on my computer, the power button stays off but everything else in the computer boots up. there is no display on my monitor and i have a red light next to CPU on the ex debug light so i assume it’s something to do with that. i looks around on the internet and it says my bios firmware isn’t up to date, but how am i supposed to check that when i have no display on my what computer is doing, please help
https://linustechtips.com/topic/1516349-red-cpu-ez-debug-led-no-display/
What motherboard do you have, and what CPU? Cmon, we are not wizards, please provide that information. Your motherboard box could give use an information about your current BIOS, for example B550 rev 1.2 and with that information we could find your BIOS information. Lets start from that.
Ryzen 5 5600x | XFX MERC RX 7900 GRE  | 2x16GB 3200MHz | Samsung 980 1TB | 1 TB WD Blue | 120GB A400 Kingston Gigabyte M2 NVME 512GB  | BeQuite Straight Power11 80+ Gold 750W
hi my apologies, i was gifted this computer so i don’t have any boxes. but i believe my motherboard is a Z170A Sliplus, (that’s what it says in the motherboard) and my cpu is a GTX 1080.
Thats a GPU not CPU. Open up a task manager if you're using windows, then performance tab, and you will see a CPU. If you're using Ubuntu for example you can use this command in terminal
cat /proc/cpuinfo  | grep 'name'| uniq
As far as I know Intel didn't have much BIOS issues like Ryzen where you need to update it.
You can check for supported CPU list, but provide me with the CPU infromation when you can https://www.msi.com/Motherboard/Z170A-SLI-PLUS/support#cpu
he cant even POST...
@sammoss05I'd recommend trying to reset CMOS by turning the PC off, turning the power supply off (the O side is down rather than the | side), remove the button battery on the motherboard, press and hold the power button for 10 seconds, then put the battery back in, power up the power supply again, and power up the computer.
If that doesn't work, start changing the ram sticks order/combination/permutation to isolate for any bad sticks. The CPU LED can be caused by a dead CPU or dead memory channels.
Specs:
  • 5950X -30 all core curve, +200 Mhz offset
  • H150i 360mm AIO
  • Asus X570 Dark Hero
  • 4x8GB DDR4 3600 CL14
  • Asus Strix OC 3080 Ti
  • EVGA 1600G+
  • 13xAL120 V2 Uni fans
Oh well, im just  tired, my fault.
so my computer is showing display again. i tried to reset CMOS but idek if i did it or even did it right lol but i tried. the cpu i have is the intel core i5-6600k
Thats great to hear, well just unplug everything, remove CMOS battery for few minutes, return it and thats it. Great that it works again 🙂
