Zotac EN-980 Mini PC cooling issue
Here is a guide for an aio: https://www.custompc.com/how-to-change-aio-liquid-cooler-coolant
first step is to get all the materials you’ll need. You’ll need new thermal paste, and new coolant at a minimum. You’ll also want a small brush like a toothbrush for cleaning and a small bottle/ pipe brush for cleaning out lines.
Next remove all of the blocks off the components so you have the cooling loop away from the components. Then you’ll want to disassemble the entire loop. Take a picture before disassembly so you can verify you’ve reassembled correctly.
after disassembly, use pipe brush to clean out all of the pipes. A warm water with dish soap bath is a good cleaning medium. Also clean the inlet and outlet ports on the blocks. Rinse and dry when cleaned.
you’ll want to take apart all of the blocks and scrub the inside part with your small brush and your soapy water to get rid of any accumulation there. Rinse and dry the pieces when done.
If there is a blockage it is in the rad or the blocks. you can blow into the rad to see if it is stopped up. The rad is harder to clean out. Pour in boiling water and let it sit and cool off for a bit. Fill it about halfway only. Then shake the hell out of it for a minute, empty it. If it runs clean you’re good, if not keep doing that until no more gunk comes out. Last, flush with distilled water.
You’ll also want to verify your pump works. They do wear out sometimes, depending on the design. You’ll need a 12v power source and a way to connect it to the pump. Stick the inlet pipe into a bowl of water and aim the outlet somewhere you don’t mind getting wet and give it the juice. A working pump will give you a nice stream. Or you might replace the pump due to age anyway.
After everything is cleaned, reassemble and refill with your new coolant. You have to get all of the air out so give the different parts of the loop a little shake as you fill up. See the link I put at the top for the procedure.
Hope this helps. It’s going to be a project.
