Choosing PC Components for PC Build
Go to solution Solved by SorryBella,
11 minutes ago, Dmag said:
Will make it public, sry my mistake.
Just not a fan
What do you mean by "not a fan"? Wont know until you try, and in terms of value for gaming only all AMD makes a fuck ton more sense right now.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  (€236.90 @ Switch Technology)
CPU Cooler: Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  (€56.90 @ Switch Technology)
Motherboard: ASRock B650M PG RIPTIDE Micro ATX AM5 Motherboard  (€199.90 @ Globaldata)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€136.00 @ PCDIGA)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€128.50 @ Switch Technology)
Video Card: Sapphire PULSE Radeon RX 7900 XTX 24 GB Video Card  (€1117.16 @ PC Componentes)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case  (€69.90 @ Switch Technology)
Power Supply: SeaSonic FOCUS 850 W 80+ Gold Certified Semi-modular ATX Power Supply  (€109.90 @ Globaldata)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  (€99.00 @ Globaldata)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan  (€4.50 @ Switch Technology)
Total: €2158.66
Generated by PCPartPicker 2023-06-26 17:01 WEST+0100
Though if you insist?
CPU: Intel Core i7-13700 2.1 GHz 16-Core Processor  (€410.90 @ Switch Technology)
Motherboard: Gigabyte Z790 UD ATX LGA1700 Motherboard  (€240.91 @ PC Componentes)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  (€150.34 @ PC Componentes)
Storage: TEAMGROUP MP33 PRO 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€114.05 @ PC Componentes)
Video Card: Zotac GAMING Trinity GeForce RTX 4080 16 GB Video Card  (€1282.90 @ Switch Technology)
Power Supply: Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€146.09 @ PC Componentes)
Total: €2575.49
Generated by PCPartPicker 2023-06-26 17:04 WEST+0100
Budget (including currency): Around 2 500,00€
Country: Portugal
Games, programs or workloads that it will be used for: It will mostly be used for games like :
- Hogwards Legacy
- Assassins Creed Series
- Some other open World games that i may like
- Some League of Legends
I will also use it for some work but nothing too complex.
Other details :
Hi ,
I am new here and this is my first time choosing components for a PC. I will have the store build it for me.
It will mostly be used to playing games at 1440p, i already have the monitor.
If possible i would like the least ammount of RGB. Not a bif fan.
If you want to change cases please choose either Corsair or Lian Li and the size must be Mid tower.
I do not want AMD parts .
I also have some questions even though trey migth sound dumb
- Should i buy extra fans ? And i yes, how many (i know it depends on the case but what is the ideal number )? Do i need to buy a fan controler ?
- Do i need to buy something for bluethooth or does it come with the motherboard or some other component ?
This is the build i have rigth now :
https://pt.pcpartpicker.com/user/Dmag/saved/hHgphM
All oppinions are appreciated.
Thank you for the attention.
https://linustechtips.com/topic/1515670-choosing-pc-components-for-pc-build/
Part list is private...
Why no AMD parts ? religious reasons ? 😄
Just not a fan
Total: €2158.66
Total: €2575.49
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Total: €2158.66
Total: €2575.49
OK
I will take into consideration your build, but like i mentioned i prefer Lian Li or Corsair cases, so i will need to change the one you choose.
Is there any difference between air cooler or liquid cooler ?
And if i choose a liquid cooler but still want some fans, do i need a fan controller ?
Unless if you live in a consistent high ambient scenario (heat waves aren't it, I'm talking 30-35 room ambient for almost all year like in ME or SEA) or uses it for constant 100% load, you'll be fine on air-cooling for both CPU sides right now.
Then i need a liquid cooler, around here from april to september temperatures can get to 45ºC. Do you have any reccomendations ?
Outdoor ambient ≠ indoor ambient unless if you completely skimp on insulation.
280mm or 360mm is fine. Arctic Freezer 2 or Deepcool LS and LT line is the 3 id actually give a damn. Honorable mention yet chokingly expensive would go to EK Nucleus DRGB (if you can find the older EK AIO line, thats a recommendation), Corsair H Elite line, Be Quiet Pure Loop, and Phanteks AIO.
OK thank you i will take it in consideration.
On saturday it was 44º C outside, inside was 28-29, luckily our building is the shade of another one.
If i buy a liquid cooler should i still buy fans ? and if yes, how many ? do they need a controller ?
Depends on your case configuration at the end. A lot of cases comes with their own fans.
In terms of controller, you can daisy chain fans up to 3-4 depending on the amperage of the fans. From there you can put them onto the fan header on your motherboard. The advantage of a controller would be cable management and thats it.
That 120mm fan goes inside the back of that case for a exhaust fan.
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor  (€391.50 @ Switch Technology)
CPU Cooler: *Deepcool AK620 68.99 CFM CPU Cooler  (€65.97 @ PC Componentes)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  (€175.90 @ Switch Technology)
Memory: *Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  (€124.99 @ Corsair)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€128.50 @ Switch Technology)
Video Card: Gigabyte EAGLE OC GeForce RTX 4070 Ti 12 GB Video Card  (€909.90 @ Globaldata)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  (€71.90 @ Switch Technology)
Power Supply: *MSI MPG A850G PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (€147.39 @ PC Componentes)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  (€4.90 @ Globaldata)
Total: €2119.95
Generated by PCPartPicker 2023-06-26 20:51 WEST+0100
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/black-solid/
https://www.msi.com/Power-Supply/MPG-A850G-PCIE5
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/us/en/products/sku/230491/intel-core-i713700f-processor-30m-cache-up-to-5-20-ghz/specifications.html
https://www.deepcool.com/products/Cooling/cpuaircoolers/AK620-High-Performance-CPU-Cooler-1700-AM5/2021/13067.shtml
https://www.westerndigital.com/products/internal-drives/wd-black-sn770-nvme-ssd#WDS200T3X0E
