Replacement motherboard
14 minutes ago, PhGnomez said:Is a 6th Gen CPU just simply too old to run on modern 11? 12? generation boards?
Yes. Intel motherboards only really support 2 generations per socket, on some rare cases 3. 6th gen is LGA 1151 version 1 and only works on those first few.
14 minutes ago, PhGnomez said:I've found the same boards for sale used at the $100 range; but that seems a bit of a silly purchase for now a 7? year old board in used condition.
I don't think you're looking in the right spot for them, just looking up "Z170" on eBay the first three boards are sub-$100, one is down to $63. If you look a little harder I'm sure you could probably find one for as low as $50, this is just me looking for 2 minutes. If you went down to H170 or B150 if you don't want to overclock that would get it even cheaper.
Used boards after ~3 years out of production stop depreciating and hold their price until about 6-7 years old when they start increasing in price because the working ones get more and more rare as ~5 years in is usually when boards start randomly dying out. If this was a year or so from now, $100+ does sound about what I'd expect for them.
