Budget (including currency): 1400USD or 120000INR
Country: India
Games, programs or workloads that it will be used for: Intense Games, Unreal engine 5.2
https://pcpartpicker.com/list/sRMCsL
I am a noob in PC building
I have designed this pc for first time, are the components sufficient to run software like Unreal Engine 5.2 and run intensive games?
Please suggest better and cheaper alternatives if you find any. And is this pc futureproof for like next 5 years?
https://linustechtips.com/topic/1514161-first-time-building-a-pc/
DDR5 5600 CL36 is slow.  I would pair up that 12700K with this board down below and a set of DDR4-3200.
https://mdcomputers.in/msi-pro-b660-a-ddr4.html
MSI PRO B660-A DDR4 ₹14,800
https://www.msi.com/Motherboard/PRO-B660-A-DDR4
Good cpu cooler.
https://www.pcshop.in/product/deepcool-ag620/
DEEPCOOL AG620 ₹4,190
https://www.deepcool.com/products/Cooling/cpuaircoolers/GAMMAXX-AG620-Dual-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
Country: India
Badly balanced, I suggest that instead, will be way better for gaming
PCPartPicker Part List
CPU: Intel Core i5-13400 2.5 GHz 10-Core Processor  ($199.99 @ Amazon)
CPU Cooler: Deepcool AK500 68.99 CFM CPU Cooler  ($44.99 @ Newegg)
Motherboard: MSI MAG B660 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($195.00)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  ($95.99 @ Newegg)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($109.99 @ Amazon)
Video Card: XFX Speedster MERC 319 Radeon RX 6950 XT 16 GB Video Card  ($599.99 @ Newegg)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: EVGA 700 GD 700 W 80+ Gold Certified ATX Power Supply  ($92.99 @ Amazon)
Total: $1433.93
Generated by PCPartPicker 2023-06-19 05:07 EDT-0400
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  ($239.00 @ B&H)
CPU Cooler: Thermalright Assassin X Refined SE ARGB 66.17 CFM CPU Cooler  ($19.89 @ Amazon)
Motherboard: Gigabyte B760 DS3H AC DDR4 ATX LGA1700 Motherboard  ($139.99 @ Amazon)
Memory: Mushkin Enhanced Redline Stiletto 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($56.99 @ Newegg)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($79.98 @ Amazon)
Video Card: XFX Speedster MERC 319 CORE Radeon RX 6800 XT 16 GB Video Card  ($519.99 @ Newegg)
Power Supply: Deepcool PM850D 850 W 80+ Gold Certified ATX Power Supply  ($90.31 @ Amazon)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fans 5-Pack  ($23.99 @ Amazon)
Total: $1265.13
Generated by PCPartPicker 2023-06-19 05:10 EDT-0400
I dont know the prices in India, so i tried matching the USD amount, but if possible you could swap in a 6950XT for just 80 $ more
Total: $1433.93
Can you please explain how it is badly balanced? Are the components not compatible with each other? Also part picker is saying that the motherboard and the CPU have compatibility issues... can you suggest another motherboard?
38 minutes ago, _Omega_ said:
I dont really know what the special requirements are for working in unreal engine 5.2, but for gaming the CPU and GPU are kind of a mismatch
So which one among them should be replaced and can you suggest a better alternative please?
Good cpu cooler.
So are you suggesting that I should use the ddr4-3200 with ddr-5600 cl36? Is the ddr4 faster than the ddr5?
