Hi all,
Firstly, can I ask what would be a minimum flow rate for a custom loop cooling a 9900k and a 3080ti before it starts to affect thermals negatively? Both the CPU and GPU are OC'd but not massively.
I have a recent build in a Hyte Y60, loop as follows:
Corsair XD5 Pump / Res > 3080ti > EK Coolstream SE120 > 9900k > EK Quantum Surface S360 > EK Quantum Surface X240M > Back to XD5.
I also have a Barrowch OLED flow meter and coolant temp sensor which even with the pump PWM speed set to full chat shows no more than 2L / min.
I wouldn't normally be worried but my thermals are much higher than expected and while I attribute this to the case sitting in an area that has very poor ventilation I was thinking that maybe poor flow rate was also a factor.
The 9900k is running at 5.1Ghz all core, delided and liquid metalled with temps hovering around 60-70C when gaming which I'm pretty happy with but my 3080ti keeps creeping up to 95C on the hotspot and 80ish on the core. I've re-seated the block and reapplied paste a number of times. I'm starting to look at under-volting the GPU but just wanted to check that flow rate wasn't a major factor.
I have another dual-loop build in a Tower 500 with 2 Barrowch sensors showing upwards of 7L / min on each loop which is clearly much higher than my Hyte one.
Any ideas?
Cheers
Chris
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
https://linustechtips.com/topic/1512793-custom-loop-flow-rate-question-issue/
flow rate is not normally a problem any more. 1 gpm is good enough. thoe each gpm you get is about 1c drop.
back in the day what what we did was get as much gpm but then the jet plate on cpu block was a think witch made a bottle neck for speed. but got good temps. and there were other problem of having so much gmp.
imo barrow or bykski sensors are not really precise if u compare to aquacomputer ones
however the main object is keeping your components cool, if yer cpu & gpu are decently cool on max load then yer good... that said how are your fans configure; are they pulling fresh air into the case or exhausting, u can easily test it by removing the glass panel & load test (if temp drops it means yer current fan setup is not gettin enough fresh air pass yer rads)
from my exp my d5 pump does dump some heat into the loop when u run them max out, my coolant temp increase by 1-2c when i max out the d5
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
Thanks for the info guys.
I think I'll tinker with my fan setup as taking the main glass side panel helped a lot.
The main issue is clearance round the case as it sits in a custom MDF AV unit with only 2-3 cm of space at the side, rear and top.
As it stands the case sites side on with the rear, top and back side of the case close to a surface.
Rear 120mm rad is intake (push/pull). Top 360 is intake (pull) and side is exhaust (push/pull).
I know that the rear and top would typically be exhaust but with pretty much all rad sided surfaces stuck against a wall / surface, I kinda thought that might cause issues.
See pic below to give you a better idea of positing.
Happy to hear any suggestions on fan config.
Cheers
Chris
You're covering most/all of your vents with that positioning. You're always going to have temp problems if you don't resolve that. I suggest positioning it on an angle if you can't relocate it or turn it 90 degrees.  At the very least, move it forward to the lip of the shelf and to the right.
I hope that the particulates in that colorant don't start falling out and filling areas.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
Thanks buddy.
I can move the case another couple of cm's forward which will give a bit extra breathing space and I think I can reduce the size of the half shelve to move it further right. I don't remember the last time I booted up the PS4 so can relocate that without issue.
16 hours ago, ChrisLoudon said:
Thanks buddy.
how is the fans setup? looks like the back is intake and side exhaust but what about the bottom and top?
Yeh, back is intake, side exhaust, top is currently intake and bottom also intake.
I know that the top really should be exhaust but I was worried that with the limited clearance I might get better performance with that being an intake and just keeping the side glass window off.
The result right now is very good as my temps have dropped dramatically.
C
