Info regarding pc components...
Solved by bezza...,
1. yes it is good enough
2. there might be a small bottlneck in some games but this is fine
3. there will be no notisable difference
personally i would go with the 6700xt or 6750xt instead of the 3060ti as it has more vram, performs better and can be found cheaper
Ryanwake ·
Posted in General Discussion1 -
1
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases0 -
2
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
10
derekchan ·
Posted in New Builds and Planning16
play_circle_filled
Latest From ShortCircuit:
