I need some help with picking out parts for an Intel Streaming/gaming pc.
Go to solution Solved by SorryBella,
3 hours ago, Mr.Peanut said:
So I’m in the US I’m planning on getting a case, I’m going for gaming and streaming. I’ll need mobo, cpu, ram, and power.
Remember to press quote to get a response from someone.
Wait so do you need the case or not? Assuming you do have the storage already:
Intel, over the 105% budget limit but this will provide a bit more upgrade path.
PCPartPicker Part List
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  ($204.99 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($36.90 @ Amazon)
Motherboard: Gigabyte B660M AORUS ELITE AX DDR4 Micro ATX LGA1700 Motherboard  ($119.99 @ Newegg)
Memory: Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($49.97 @ Amazon)
Case: Montech X3 Mesh ATX Mid Tower Case  ($59.99 @ Newegg Sellers)
Power Supply: MSI MPG A650GF 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($74.62 @ Amazon)
Total: $546.46
Generated by PCPartPicker 2023-06-09 21:37 EDT-0400
AMD, under budget for the same initial performance but your only upgrade path is 5800X3D.
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($130.05 @ Amazon)
CPU Cooler: Thermalright Burst Assassin 66.17 CFM CPU Cooler  ($25.90 @ Amazon)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard  ($106.99 @ Amazon)
Total: $447.52
Generated by PCPartPicker 2023-06-09 21:40 EDT-0400
Hey yall, I'm planning on building an Intel-based pc I've got AMD 6600 graphics already and I have a budget of $4-500 and didn't know which parts to pick that wouldn't throttle each other.
15 minutes ago, Mxsaa said:
I mean I have no idea how Intel CPUs pair with AMD GPUs but that's another story..
The same way AMD CPUs pair with Intel GPUs, or Nvidia GPUs, or AMD GPUs.
18 minutes ago, Slottr said:
For what use specifically? What country?
^^^ What country and is it only for gaming or do you need to get other stuff done?
Main PC // Spare PC (currently in pieces):
CPU: Ryzen 3700X // i9 7980XE @4.0GHz/1.11v
Cooler: Noctua NH-D15S // EKWB Supremacy Block/EKWB Pump-Res and Tubing/360mm slim + 280mm thick rads
Motherboard: ASRock B450 ITX/ac // EVGA X299 Dark
RAM: 2x16GB Team Group DDR4 @3600Mhz CL18 // 4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Intel ARC A770 LE // Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 2x 1TB MX500 + 525GB MX300 // 1TB 970 Evo + 250GB 960 Evo + 500GB Atom30
Optical Drives: None // LG WH14NS40
PSU: EVGA 850W GM // EVGA 1600W T2
Case & Fans: Node 304 - Stock front fans, NF-A12x15 rear // Corsair 750D Airflow - 6x Noctua iPPC NF-F12 + 5x Noctua iPPC NF-A14 PWM
OS: Windows 11 // Linux Mint
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
1 minute ago, Mxsaa said:
I meant like how well it does it
CPU = CPU as far as the GPU is concerned. Both AMD and Intel support reBAR (AMD calls it SAM) on their modern platforms, both are constantly neck and neck on performance, so there's no difference that would effect the GPU. I've run Intel with AMD, Intel with Nvidia, Intel with Intel, AMD with AMD, AMD with Nvidia, I don't currently have anything AMD to try with my Intel ARC but I wager it'd work exactly the same as it does with my Intel CPU. Oh and going back further I believe my PowerPC Mac used... either an Nvidia or Radeon GPU, they came with and supported both IIRC, just forget which mine had.
Mouse: EVGA X17
Total: $546.46
Total: $447.52
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My. Name. Is. Frill.
