Budget (including currency): $2,000 USD
Country: USA
Games, programs or workloads that it will be used for: ATM Minecraft, ROBLOX, BeamNG, Switch emulator. I'm planning on getting heavier games and even some heavy shaders for Minecraft.
Other details
Part Picker list upgrading
i5-2400      --> i5-13600k
1050 Ti       --> 4070 Ti
20 GB ram --> 64 GB
500 GB      --> 2 TB storage
I have 2 1080p monitors. one ill be running 60 and the other 165. I'm hoping on replacing my main with a higher resolution one in the future.
I'm hoping to get this within the next week or 2.
I've put the parts list though some friends and they have helped me adjust the parts list to this.
No peripherals are needed.
I'm going to wat for the GPU to get back in stock at best buy so its $100 less.
my main concern is if the parts list looks fine. I don't care how overkill this is with the games I currently play.
https://linustechtips.com/topic/1511992-first-pc-bulid/
1050 Ti --> 4070 Ti
20 GB ram --> 64 GB
You don't need 64 gigs. 32 will be good
PCPartPicker Part List: https://pcpartpicker.com/list/mgh2tn
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($439.00 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE ARGB 66.17 CFM CPU Cooler  ($36.90 @ Amazon)
Motherboard: MSI MAG B650 TOMAHAWK WIFI ATX AM5 Motherboard  ($219.99 @ Best Buy)
Memory: G.Skill Trident Z5 Neo RGB 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($114.99 @ Newegg)
Storage: Samsung 980 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Adorama)
Video Card: XFX Speedster MERC 310 Radeon RX 7900 XT 20 GB Video Card  ($785.59 @ Amazon)
Case: Lian Li LANCOOL 216 ATX Mid Tower Case  ($109.99 @ B&H)
Power Supply: Thermaltake TOUGHPOWER GF A3 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  ($169.99 @ Amazon)
Total: $2006.44
Generated by PCPartPicker 2023-06-09 10:50 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978143
You can easily get a 7900xtx with this budget, and the Nitro+ is an excellent cooler:
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  ($315.08 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  ($179.99 @ Newegg)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-5600 CL32 Memory  ($84.99 @ Amazon)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($122.49 @ Amazon)
Video Card: Sapphire NITRO+ Radeon RX 7900 XTX 24 GB Video Card  ($950.00 @ Amazon)
Case: Deepcool CG560 ATX Mid Tower Case  ($69.99 @ Newegg)
Power Supply: Super Flower Leadex V Platinum Pro 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($159.99 @ Newegg Sellers)
Total: $1919.43
Generated by PCPartPicker 2023-06-09 13:41 EDT-0400
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978319
Country: USA
Other details
1050 Ti       --> 4070 Ti
20 GB ram --> 64 GB
some parts in your list doesn't make sense to me.
e.g. gigabyte eagle is usually their MSRP card, not the premium tier, and theres much cheaper MSRP cards.
i know ddr5 is troublesome with raptor lake, but the performance you leave on the table with ddr4 would be too much for me at 2k$. given that 2 dimms are more stable than 4 dimms, I would personally chose 2x32 D5 instead, and price has came down to justifiable levels.
you don't really need thermal paste, the cooler you bought will come with some. difference probably not that big.
The case has slightly cheaper white version (which i actually prefer but its a taste thing), or 40$ cheaper non-rgb version, which is the one i'd get.
the PCIE5 + ATX3.0 market is already here, ppl is still stuck on PSU with (2021) behind them, don't do that when the GPU comes with that new power connector. as a bonus, in pcpartpicker with "PCIE 12+4-PIN 12VHPWR CONNECTORS" set to 1-2 instead of 0-2, I SEE LITERALLY NO TRASH PSUs, they are ALL GOOD VALUE, so you can literally pick a wattage and buy any of them really.
PCPP list with above changes: https://pcpartpicker.com/list/8BNsyK
cooler: peerless assassin is worth the 7$ extra, also it cost more to remove the rgb... thats why i chose the rgb version.
other than 4070 ti available for much cheaper, and not using the actually quite good latest PSUs, i see nothing really wrong.
it was hard chosing the ram, i just picked something that looked like it had fairly good gb/$ and freq/timing, but you can also get 7200cl32 now, for double the gb/$. check out hwub on d5 scaling https://www.youtube.com/watch?v=XW2rubC5oCY
the funny thing is d5 version of the msi board you picked is actually cheaper.
also, there's not much review on z790 motherboards yet, so again the motherboard pick is a shot in the dark. that goes for z790 d4 too. i usually trust hwub as they give detailed info on vrm configuration and temperatures, and reports on any problem they find with each board. what i chose looks decent to me.
so yea, just get an idea of d4 d5 tradeoffs in cost performance and see if you'd like to switch over.
oh and i set it to 13600kf instead of 13600k, honestly for 10$ i would chose 13600k too.
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978324
Country: USA
Other details
1050 Ti       --> 4070 Ti
20 GB ram --> 64 GB
32GB of RAM should be plenty, and you definitely want a better air cpu cooler. You should also do a 1TB & 2TB combo for the storage. The 1TB being for your boot drive, and the 2TB for most/all of the games.
https://pcpartpicker.com/list/FmrwTn
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  ($299.99 @ Newegg)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler  ($89.95 @ Amazon)
Motherboard: MSI MAG B760 TOMAHAWK WIFI ATX LGA1700 Motherboard  ($199.95 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  ($92.99 @ Newegg)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($45.90 @ Newegg)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.00 @ Newegg)
Video Card: MSI GAMING X TRIO GeForce RTX 4070 Ti 12 GB Video Card  ($814.99 @ B&H)
Case: Fractal Design Pop Air RGB ATX Mid Tower Case  ($89.99 @ B&H)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.99 @ Best Buy)
$1882.75
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978393
i felt like a lot of people were going to recommend going to 32 gigs but i had some friends recommend just going 64 cause why not. is the part list fine as in there should be no major bottlenecks. i would like to stick with intel and nividia for those parts. i don’t really care for what’s cheaper and better and would like to know that the parts will work fine together.
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978686
  • The cpu cooler you listed is insufficient for that cpu. A couple of selections from Noctua and Deepcool would be far better.
  • 64GB of RAM just doesn't make sense. You can allocate the funds to the other parts of the build.
  • I did recommend intel and nvidia, but a better case. The case you listed doesn't have enough fans, and I'm sure the RGB control is terrible. It seems to be a popular case, to be sure, but I wouldn't recommend it.
Quote
  • It's too over the place. You have subpar parts on one side of the list, and way overkill on the other.
  • I would still recommend the 1TB & 2TB SSD combo. You'll want a lot more storage for your games.
  • 32GB is actually somewhat overkill right now. 64GB is if you're doing production work, heavy on the video editing side (even then, better gpu is better than more RAM), etc.
https://pcpartpicker.com/list/chsvH2
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978705
https://pcpartpicker.com/list/4DcNfv
id like to stick to the current gpu as I really like the looks of it but i have adjusted some parts.
i also really like the 3 fans with my case and meets all my expectations so id rater not change that
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978737
CPU: *Intel Core i7-13700F 2.1 GHz 16-Core Processor  ($329.99 @ Amazon)
CPU Cooler: *Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler  ($49.99 @ Newegg)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($164.99 @ Amazon)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($117.99 @ Newegg)
Storage: *Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.00 @ Newegg)
Video Card: *Asus TUF GAMING GeForce RTX 4070 Ti 12 GB Video Card  ($799.99 @ B&H)
Case: *Lian Li LANCOOL 216 ATX Mid Tower Case  ($109.99 @ B&H)
Power Supply: *Corsair RM850e (2023) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($129.99 @ Amazon)
Total: $1801.93
Generated by PCPartPicker 2023-06-10 04:26 EDT-0400
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978777
Yeah, but you need at least one fan at the rear, for exhaust airflow too.
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15978882
20 hours ago, Dat_One_Guy said:
i added a fan at the back. would you say this looks fine for a bulid? even with is flaws.
https://pcpartpicker.com/list/jHq7k9
Yep. You can alternatively do 4000X RGB case btw. I actually almost forgot about that one. O_O lol. Just giving more options.
https://pcpartpicker.com/product/6qFKHx/corsair-icue-4000x-rgb-atx-mid-tower-case-cc-9011204-ww
https://linustechtips.com/topic/1511992-first-pc-bulid/#findComment-15980258
