Just now, dilpickle said:
GPUs don't come with power cables. You need to use the cables labeled PCI-E from your power supply.
Gpus don’t USUALLY come with power cables. Sometimes 40 series cards (and others) will come with special splitters. However, if the gpu didn’t come with cables (splitters) out of the box, you don’t need them.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1511842-cables-question/#findComment-15976931
A splitter is not a power cable. Please tell me what you plug the splitter into.
https://linustechtips.com/topic/1511842-cables-question/#findComment-15976932
I disagree. A splitter has cables that deliver power. It’s not what you typically think of as a power cable as it doesn’t plug directly into a psu, but it is still a “power cable” this is why in the post you quoted I put “splitter” in parentheses after I said cable. Regardless of the exact meanings and definitions, the answer to the post is simply “if the gpu didn’t come with it you don’t need it”.
Main Gaming Machine
https://linustechtips.com/topic/1511842-cables-question/#findComment-15976935
Um no and this type of pedantry doesn't help the OP so why are you even wasting space with all this nonsense.
https://linustechtips.com/topic/1511842-cables-question/#findComment-15976940
That's kinda nitpicking...
A splitter is like an extension cable, it has to be plugged to the "real" power cables, that are the ones plugged in the PSU
https://linustechtips.com/topic/1511842-cables-question/#findComment-15976999
1 hour ago, ClassicWhite said:
Might also say the gpu is the 4070 msi ventus 3x and uses 1 pcie and the cable have 2 8 pin pcie.
If the cables that came with your psu fits, you are fine.
I don't think the Ventus 4070 needs that new 12pin connector (which could be an adapter cable you would find in your graphics card box).
So I would just find the right pci-e power cable and plug in.
What is generally warned about, is using power cables from different PSUs, as their inner layout can differ and cause all kinds of problems and shorts, but using approved cables with their designated PSU is not an issue.
mITX is awesome! I regret nothing (apart from when picking parts or have to do maintainance *cough*cough*)
https://linustechtips.com/topic/1511842-cables-question/#findComment-15977668
