First PC Build
Go to solution Solved by PDifolco,
8 minutes ago, HellBison said:
Budget (including currency): 1200€
Country: Belgium
Games, programs or workloads that it will be used for: RPG, Hack'n'Slash, Rogue Like/Lite
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): https://pcpartpicker.com/list/nLxJjZ
Hi everyone, I'm finally starting to build my first pc! Even though I've been learning about the subject while wavering between cracking or not for a few months now, I'd like to have the opinion of people who know a lot more about it than I do. My biggest concern is the compatibility of the various components (especially in terms of physical constraints and bios compatibility between MoBO and CPU). I'm looking for a configuration that allows me to be comfortable with most recent games, I don't need to have exceptional performance on them. If anyone could confirm that this configuration would work properly, I'd be reassured!
Thank you all and have a nice day!
Use localized pcp in your (low) country 🙂
- Overpriced cooler
- 3060 is a bad deal, 6700XT is significantly faster for not much more
- Better PSU
PCPartPicker Part List
CPU: *AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  (€182.95 @ Megekko)
CPU Cooler: Deepcool AK400 66.47 CFM CPU Cooler  (€38.85 @ Megekko)
Motherboard: Asus ROG STRIX B550-A GAMING ATX AM4 Motherboard  (€148.95 @ Megekko)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€70.85 @ Megekko)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€64.95 @ Megekko)
Storage: *Seagate Barracuda Compute 2 TB 3.5" 7200 RPM Internal Hard Drive  (€51.85 @ Megekko)
Video Card: Asus DUAL Radeon RX 6700 XT 12 GB Video Card  (€396.95 @ Azerty)
Case: *Corsair 4000D Airflow ATX Mid Tower Case  (€82.95 @ Megekko)
Power Supply: NZXT C650 (2022) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€83.85 @ Megekko)
Total: €1122.15
Generated by PCPartPicker 2023-06-01 16:24 CEST+0200
Country: Belgium
https://linustechtips.com/topic/1510528-first-pc-build/
I would suggest that if you're buying CPU/GPU from the previous gen, look into the used market and get better value for your money.
other than that, please don't buy that HDD or any HDD for that matter. You can get a sata ssd for only 20 dollars more. HDDs make a ton of noise and, believe me, your ears will thank you once that constant buzzing is gone from your room.
https://pcpartpicker.com/product/DZkj4D/silicon-power-a55-2-tb-25-solid-state-drive-sp002tbss3a55s25
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966778
Country: Belgium
- Overpriced cooler
- Better PSU
Total: €1122.15
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966780
- Overpriced cooler
- Better PSU
Total: €1122.15
Wow, thanks for the quick reply and the good advice!  At least, we have good beers and chocolate 😄
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966793
Thanks, I'll have a look!
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966796
Thanks!
I'm just right next to you in France (fine wine and women 🙂)
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966799
https://be.pcpartpicker.com/list/rkBnZw
5500 + 6950xt + 32gb 3600c18
cpu wise youll wanna set vcore to 1.4v with medium/no llc and multiplier to 47/48 on all cores
I assume youll wanna leave rams stock but if you are interested in actually leveraging the imc of cezanne and making up for the cache deficit you can opt for some crucial 3200c22 which will come with better micron ics, fclk capability on cezanne allows for 5000+ ddr4 in 1:1 fclk though you should be aiming for 4400-4600 so it isnt too much of a pain to oc and so rams arent gonna be too volatile
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966831
CPU: *AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (€142.95 @ Megekko)
CPU Cooler: *Deepcool AK400 66.47 CFM CPU Cooler  (€38.85 @ Megekko)
Storage: *Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€64.95 @ Megekko)
Video Card: MSI GeForce RTX 3060 Gaming X12G GeForce RTX 3060 12GB 12 GB Video Card  (€356.95 @ Azerty)
Power Supply: Corsair TX650M 650 W 80+ Gold Certified Semi-modular ATX Power Supply
Total: €958.30
Generated by PCPartPicker 2023-06-01 18:22 CEST+0200
https://linustechtips.com/topic/1510528-first-pc-build/#findComment-15966992
