Hello I need your help
Go to solution Solved by filpo,
2 minutes ago, Abdellah714 said:
thanks for you reply and yeah  i just want to play gta v on very high settings I'm not planning on playing high modern games because I'm on a budget my current gpu can run it but its dying so that why i need a new gpu anyways thanks again
try and look for a 1650 super as it performs much better for the price. But on the psu that psu will be perfectly fine for your application. Maybe try and look for a 650w or 600w like the thermaltake smart BM2
You wills be disappointed with that card in any modern game - it doesn’t have enough vram. If you are just playing older titles on lower resolution it’ll be ok. If not, try to get at least a 1080 or better. 600w is enough for a 1080. The 1650 can do fine on 500w.
https://linustechtips.com/topic/1510257-hello-i-need-your-help/#findComment-15964799
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1510257-hello-i-need-your-help/#findComment-15964812
