Please help me out selecting a GPU
Solved by adm0n,
I'd say the most bang for the buck, you'll get with the 5600XT. And the price is quite fair for that in my opinion. The other cards are not totally in a different class, so you won't really be getting a significant upgrade to warrant the extra cost. And this way, you'll feel less friction to upgrade again, when you have saved up a bit more in a few years.
If you want something better, I'd check out something like the 6600XT new or the newly launched 7600 from AMD.
But it would also help, if you'd tell us what kind of games you want to play and at which resolution.
