Yamaha P-35 Electric Piano power adapter
Katze
So my brother and I have the same Piano, a Yamaha P-35.
One of the power supplies was presumed lost, but I just found one that looks like it matches the volts and amps. I think it will be fine, but I'm not sure about the +12v on the Powermaster and wanted to get a sanity check xD
Original Yamaha adapter:
The one I found:
The one I found:
As long as the barrel plug is the same size as the port on the keyboard, you're fine. The two connectors also use the same polarity, so you're good to go
