 My pc which i built about a year ago suddenly stopped working. When I looked into it i saw the Ez debug CPU light on.
It happened after i did a bios update through the msi center
I reseated the CPU
I have removed the CMOS
I tried resetting the CMOS by jumping it
Even tried the flash bios button with freshly downloaded bios.
(It only turned on for a few secs then just turn off. The manual said that it will turn off after the bios is updated. I even looked it up on YouTube, and when they  did this method, their updates took about 5 to 10 minutes but mine only took a few seconds)
Even after doing all of this, my pc still does not turn on.
That red cpu debug light is still on
My pc specs:
Ryzen 5 5600x
Msi b550 gaming edge WiFi
Corsair vengeance 32gb ram (16x2)
IGame rtx 3060 12gb
Please help 🙏 😞😞😞
https://linustechtips.com/topic/1507806-cpu-debug-light/
The red CPU debug light suggests that there could be an issue with the CPU. Maybe the CPU could be broken. If that's the case you can RMA the CPU if you bought it new.
"A computer is not slow, it just has higher expectations" -Unknown
Main PC
CPU: AMD Ryzen 9 5900X RAM: 64GB Corsair Vengeance PRO DDR4 3200MHZ (White) (4x16GB) GPU: Dell/Alienware OEM Nvidia GeForce RTX 3080 (10GB GDDR6X) Case: Lian Li Lancool II Mesh Snow White Storage: 4TB WD_BLACK SN850X (boot drive), 1TB SanDisk Extreme Pro M.2 NVME, 6TB WD Blue 5400RPM HDD, 6TB WD Gold 7200RPM HDD PSU: EVGA SuperNova 1200 P2 80 Plus Platinum Displays: Viotek GN24CB 24" 144Hz 1080p Curved + Sceptre C248W-1920RN 24" 75Hz 1080p Curved Cooler: NZXT Kraken X53 RGB 240mm (Black) Keyboard: Cooler Master CK552 Mouse: Logitech G502 Hero OS: Windows 11 Pro
Laptop 1 - Gaming
CPU: Intel Core i7-7700HQ RAM: 32GB Kingston HyperX Impact DDR4 2133MHZ (2X16GB) GPU: Nvidia GeForce GTX 1050 (Mobile) (4GB GDDR5) Model: ASUS ROG GL553VD Storage: 512GB Samsung 960 PRO (boot drive), 1TB HGST 7200RPM HDD Display: 15" 60Hz 1080p Mouse: Logitech G203 Lightsync OS: Windows 11 Pro
Laptop 2 - Productivity
CPU: Intel Core i7-7560U RAM: 8GB SK Hynix LPDDR3 1866MHZ (soldered to board) GPU: Intel Iris Plus 640 Model: Dell XPS 13 9360 (2017) Storage: 500GB Samsung 970 EVO Display: 13" 60Hz 1080p OS: Windows 11 Pro
https://linustechtips.com/topic/1507806-cpu-debug-light/#findComment-15946231
But it worked fine since May of 2022 when I built this PC. And since I don't have spare CPU/ parts, I won't be able to check whether or not it it is a CPU issue or something else
https://linustechtips.com/topic/1507806-cpu-debug-light/#findComment-15946563
Take it to a repair shop near you and see if they can confirm the cpu is dead. If you pull the cpu and hand it to them it should be pretty quick and easy for them / cheap for you.
https://linustechtips.com/topic/1507806-cpu-debug-light/#findComment-15946591
