so i got a new cheap motherboard that has no light just to test my cpu' but stays on a black screen' and dont boot  but i did have an  issue  while my screen just go black keyboard and mouse lose power  a few time' 4 days later rebooted my pc and the vga light comes on  again ' try a new gpu and also try my old gpu on a diff system it works' so im wondering if a bad cpu can cause the vga light to come on tnx yall
        system specs
Ryzen 1400
32gb vengeance rgb pro ddr 4 3600
Thermaltake tr2 600W
windows 11
B350M BAZOOKA not sure what bios
Edited by Dhuniph
https://linustechtips.com/topic/1507693-vga-light-issue/
If you don’t have post lights you will likely have something else.  Beep codes probably.  Which means you will need one of those speaker things.  They’re cheap.  The bazooka had decent VRM iirc but you may have a bios issue.  Not having post lights on a bazooka is weird though.  I wouldn’t call it a lowball motherboard.  It may be you’re just not seeing lights so you assume there aren’t any.  I would make sure you’re getting power to the board in the first place and that the board is OK.  Then make sure your bios is compatible, then worry that maybe the cpu has issues.
https://linustechtips.com/topic/1507693-vga-light-issue/#findComment-15946096
