First PC Build
1 hour ago, fourstar82 said:CPU- Intel 13th Gen Core i7-13700KF 16 Cores 24 Thread 5.4GHz Processor - $605
I would go with 13700k instead, it's just $20 more. having igpu is really handy for troubleshooting and even helps at certain workloads.
1 hour ago, fourstar82 said:GPU- Asus DUAL Radeon RX 6750 XT OC 12GB DDR6 Graphics Card - $579
Too underwhelming for the build. Your CPU is is more expensive that your gpu.
1 hour ago, fourstar82 said:Motherboard- ASRock Z790 PRO RS WIFI DDR5 LGA1700 ATX Motherboard - $337
You might not need the minor additional features. It's ok to stay with z690
1 hour ago, fourstar82 said:RAM- Corsair VENGEANCE 32GB DDR5 5600MHz (2x16GB) - $219
Same with motherboard and for compatibility, you really don't need a ddr5 for 13th gen. No real advantage or gain.
1 hour ago, fourstar82 said:SSD- Crucial P5 Plus 1TB PCIe M.2 2280SS SSD - $139
SSD- WD_Black SN770 2TB M.2 NVMe 2280 SSD - $214
Too expensive, you can get similar performance with other brands like silicon power.
1 hour ago, fourstar82 said:Case- Corsair iCUE 4000X RGB Tempered Glass Mid-tower ATX Case - Black - $205
If you really like RGB I guess. But Personally, I really don't like running the ICUE software in the background so I sold and stop using corsair parts that requires icue.
1 hour ago, fourstar82 said:Power Supply- Corsair RMe Series RM1000e - $239
If you really want to future proofs, but 850w is just fine, even for future proofing.
1 hour ago, fourstar82 said:CPU Cooling- Corsair iCUE H150i RGB PRO XT 360mm Liquid CPU Cooler - $229
Again if you really like RGB. With your case, unless you want to mount your radiator at the front(which I personally don't like), you might want to get the 240mm or 280mm variants for a top mount, which are also more than enough to cool a 13700k.
1 hour ago, fourstar82 said:Cooling- Corsair iCUE SP120 RGB ELITE Performance 120mm PWM Fan - Single Pack - $28
You must really like RGB. But go for it. More FPS and we do what we want anyway.
But yeah, either you put some of the budget for RGB or you add it on your gpu budget and get either 4070 ti or 7900 xt.
CPU: Intel Core i7-13700K 3.4 GHz 16-Core Processor ($628.00 @ Centre Com)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler ($159.00 @ PCCaseGear)
Motherboard: Gigabyte Z690 UD DDR4 ATX LGA1700 Motherboard ($269.00 @ MSY Technology)
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($109.00 @ PCCaseGear)
Storage: Silicon Power UD90 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($88.00 @ MSY Technology)
Storage: Silicon Power A80 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($169.00 @ MSY Technology)
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card ($1299.00 @ MSY Technology)
Case: Corsair 4000D Airflow ATX Mid Tower Case ($149.00 @ Amazon Australia)
Power Supply: Corsair RM850e (2022) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($155.00 @ Umart)
Total: $3025.00
Generated by PCPartPicker 2023-05-15 14:23 AEST+1000
