Hello! I just upgraded my cpu from a Ryzen 5 3600x to a Ryzen 9 5900x and also upgraded to an MSI B550M gaming plus mother board, I also added a Noctua NH-U12S SE cpu cooler. When I play games I notice how hot the computer exhaust and case is and when I restart the computer before going to windows my BIOS (I believe) warns me of CPU overheating.
If someone could please recommend what to do.
I don’t know if my GPU is to close to my CPU cooler or if I have bad airflow (maybe from dirty fans) in general.
here are the photos of my computer now.
https://linustechtips.com/topic/1506960-cpu-overheating/
This would typically mean that your mounting pressure or thermal paste application is lacking.  I would remove the cooler and remount it again to confirm your thermal paste application and mounting pressure are adequate.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939889
your gpu and cpu cooler are perfectly fine at that distance
Also if you want to see your cpu temps I would recommend either downloading cinebench r23 and hwinfo64 and us hwinfo to see your temps during a cinebench run OR get msi afterburner with rivatuner and see your cpu usage and temps in game
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939890
Thank you for replying so fast! I did take the cpu cooler off as well as the thermal paste and reapplied more and screwed in equally on each side. I can definitely do that one more time to see if that does the trick but if it still overheats do you think it could be anything else?
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939895
Perfect I will download those soon and run a test on them! Thank you
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939897
When you screw the cooler down are you tightening it down until the screws bottom out/stop? These Noctua coolers have springs incorporated into their mounting screws so that you can't overtighten them and screwing them down until they bottom out/stop insures the correct mounting pressure. So if you are not screwing them until they stop(some people get worried or scared that it's too tight and don't screw them until they stop) that would mean the correct mounting pressure is not being achieved. So if you did apply the proper amount of thermal paste, make sure the mounting pressure is correct. If the computer has a post warning message saying CPU overtemperature detected before you even get into bios, that is a pretty dead giveaway to a cooler issue, typically being a cooler to CPU contact issue.
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939913
Before anyone could suggest anything, what temperatures are we talking about? Temps of CPU and GPU under load/gaming?
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939921
Okay I will try remounting tomorrow morning because I would play Valorant and then restart my computer and before the MSI screen would appear on my display I would get that “CPU May be overheating check to make sure CPU cooler is installed properly”
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939923
Hi well I could only see the temps if I finished a game and then restated my computer right away and it was showing CPU temps in my bios as 78 degrees Celsius
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939927
that was in bios?
Total: £1040.95
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939929
A few thing I noticed
If you notice the exhaust is very hot, probable means cooler is working as intended.
Your GPU is blowing hot air right into the intake side of the CPU cooler
5900x a pretty hot chip, not the hottest ones out there now, but I still think a single tower would be a bit lacking.
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939951
What would you recommend?
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939953
So I opened Minecraft and Valorant for only 10 mins and this was the results I got from MSI Afterburner
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939955
as a cpu cooler? for a 5900x? A thermalright PA120/SE Thermalright Peerless Assassin 120 White 66.17 CFM CPU Cooler (PA120 White) - PCPartPicker
Or AK620 Deepcool AK620 68.99 CFM CPU Cooler (R-AK620-BKNNMT-G) - PCPartPicker
Total: £1040.95
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939956
are you sure your mounting pressure is correct and you put enough thermal paste on?
Do you mind taking off your cpu cooler and showing us the thermal paste on the cpu?
Total: £1040.95
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939957
I few ideas, re arrange the airflow in your case.
free solution:
1.Use back fan as intake, reverse the flow of the CPU cooler, and move one of the front intake fans to the top as an exhaust. preferably the top intake fan.
2.turn the whole CPU cooler 90 degrees to the right, so it flow bot to top, it wont be as good as fist option, but should be better than ur setup now.
Not free solution:
Get a bigger CPU cooler, to off set performance lost by sucking in hot air
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15939966
That higher temp in bios indicates the cooler is not mounted properly or something similar, forget about getting another cooler until you identify what the issue is
if as you say the thermal paste is fully covering the heatsink and you see that the mounting of the cooler spreads the paste evenly over the cpu then clean paste of cooler and cpu and look for any damage to them, is there any dents in the heatsink?
did you def take any protective film of the heatsink of the cooler??
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15940009
What is "hot" ? A 5900X is a pretty hot CPU, with 80-100W under gaming load and usually getting at around 70C in normal conditions, even more under PBO
Did you undervolt the cores ? You can also limit PPT/EDC/TDC
Don't refer to any previous experience with Intel chips they don't heat in the same way, more "linearly"
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15940052
they linked a pic or two
Total: £1040.95
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15940056
Huh ok didn't see them, too many pics ☺️
69C in BIOS is not normal, cooler is badly installed imo
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15940063
It also might be worth adjusting the front fans to accommodate for the size of the GPU.  I found moving the top fan so its blowing over the top of the GPU really helps with the NVIDIA FE cards, as its mixing fresh air directly into that GPU exhaust rather than half of it hitting the end of the GPU.  Of course this might not apply to your case as I can't see the fans in relation to the rest of the system.
Also adding a top-back exhaust fan reduced my CPU temp a few degrees.
https://linustechtips.com/topic/1506960-cpu-overheating/#findComment-15940066
