GPU without a fan?
Go to solution Solved by DoctorNick,
30 minutes ago, notAfanOf said:
Before the pitchforks come out, or I'm called an idiot, let me explain!
The use case is in a home (game) server - I just need a GPU because the ryzen 2600 I use as CPU doesn't have one onboard.
The card in question is a xfx 9600 gt with just the (dead) fan removed - ie the heatsink on and de-shrouded.
The case is, of course ventilated.
Thanks for your tips! 🙏
If you got enough airflow, then it should be fine. Also 9600GT has a max core temp of 105C. It'll shot down if it gets too hot, so don't worry.
https://linustechtips.com/topic/1506153-gpu-without-a-fan/
Might work but I doubt it. There are fanless low powered GPUs out there specifically for this.
https://linustechtips.com/topic/1506153-gpu-without-a-fan/#findComment-15933605
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1506153-gpu-without-a-fan/#findComment-15933631
it will be fine, you will probably notice 50-60 deg temps but it will drastically drop with no display plugged in because the card will go into a low power state.
Meaning literally unplug the cable from the card when you do not need it.
I assume you are just remotely connecting into the box with like ssh or vnc or something? no need for a monitor anyway
https://linustechtips.com/topic/1506153-gpu-without-a-fan/#findComment-15934160
Thanks everyone for their input! 🙏
I didn't dare to go full "nude" so I zip tied a 80 mm 12 V case fan onto it. Unfortunately the MB has only 2 fan headers so I had to power this one with a molex adapter that only gives me 5 V for quite low rpm - not really much help, but better than nothing, I guess!?
Anyway, it works fine - temps are a little high for my taste (low 80s while working with multiple apps like browser, terminal, text editor...) but they are stable. And they go down when the screen timeout kicks in.
It's a game server btw, running ARK:Survival evolved
Cheers!
https://linustechtips.com/topic/1506153-gpu-without-a-fan/#findComment-15944264
