Advice for upgrading GPU, or not...
Go to solution Solved by hollyh88,
3 hours ago, JoeThePizzaGuy said:
Is an RX 6600 (non-XT) for £180 a good deal?
Its alright, But im not really sure if its worth it for you. its always better to get at least a double in performance with your gpu upgrades. and the 6600 wont cut it. 6600xt will barely make it but the 6650xt will do double. and since you are british i would use this website and this card can be bought i believe even with financing options if you cant fully pay it in one go. might be better for your wallet as well as it does go a bit above your budget but with finance it might be a non problem for you to pay it in months orso. https://www.overclockers.co.uk/asus-radeon-rx-6650-xt-dual-oc-8gb-gddr6-pci-express-graphics-card-gx-487-as.html
but the better thing to do of course is to just wait and if you really cant run games anymore at the settings you want not even with an oc and fsr or rdr2 vulkan than yeah you could upgrade.
But what i always say to myself is only upgrade if you have the money for it and you do not have anything else you absolutely have to spend it on like taxes or bills.
Hi everyone,
I'm looking for a GPU that I can replace my current RX 580 8GB, now I'm not looking to upgrade immediately as my wallet would probably beat me up, but to take into consideration in the future perhaps. Or should I really upgrade it at all? I did purchase it second hand around October for a reasonable price.
My current specs;
Motherboard: MSI B450 Tomahawk
CPU: Ryzen 3600 3.6GHz
RAM: Corsair 2x16GB 3200MHz Vengeance LPX DDR4
GPU: PowerColor RX 580 8GB
PSU: Corsair CV550w
OS: Windows 11 Pro
Now I'd probably have to look for it second hand and not brand new, and ideally should be within the budget of under £200, perhaps if I sell the RX I could make it work.
I'm trying to sustain 1080p 60fps on high settings but for newer games it seems the GPU is struggling with it, for example even RDR2 drops below 60 even after tinkering with settings. Even with latest drivers, and the game was released in 2018... And I meet the recommended requirements for it too, which is even stranger.
Overclocking this card is probably a waste of time as this GPU generates heat and I can't reach the 1400MHz+ range anymore but I was able to overclock it stable around that figure perhaps this is due to degradation.
Thanks!
https://linustechtips.com/topic/1505864-advice-for-upgrading-gpu-or-not/
14 minutes ago, UnknownWalls said:
6800xt?
I mean if you can find 6800XT at the price of 300 pounds, more power to you. You should help me snipe 7900XT once people starts selling them on used market. But thats plain unrealistic.
But yeah in terms of GPU upgrade that 550W is going to be limiting, with 6700XT being my absolute max and even then its questionably stable considering CV series guts. 5700XT would be my used recommendation, with 6600XT or the overclocking job 6650XT being another 2. If 4060Ti and 4060 MSRP ended up being reasonable and not leg breaking (lmao), that can also be option for green team. But do be noted that none of these GPUs except 6700XT will have 12GB of VRAM which would be the new minimum as more and more modern title comes out, so keep that in mind.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Well, if you don't want to replace your PSU, I would suggest Radeon RX 6600 XT or non XT, but it definitely blew your budget of 200euro
But you can try RX 5700 XT, it's a bit over 200euro, but at least it's not priced much higher than RX 6600 XT
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
PC:
MSI MPG X870E CARBON WIFI                            (motherboard)  |    Powercolor RX 9070XT Red Devil    (Gpu)
ryzen 7 9800X3D        (cpu)   |   2560x1440 165hz (phillips 27m1c5500v)    (Monitor)
ARCTIC Liquid Freezer III Pro A-RGB 420                (cpu cooler)  |  seasonic focus plus gold 850w      (Psu)
Lian Li O11 Dynamic EVO XL                                         (PCcase)    |  Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL30   (Memory)
Steel series apex pro                                                  (keyboard)   |   Razer Basilisk v3 pro    (mouse)
https://pcpartpicker.com/user/hollyh888/saved/LX2cYJ
