Forfun 02 pro INFO and Videoidea
HI Guys
You have probably already heard about this glory by now:
I have found out where you can buy some of the core components.
For example, The motherboard: https://www.maxsun.com.cn/2023/0107/5874.html
After a short research, i have found out that the Motherboard is actually pretty different than your standard ITX Motherboard.
IT has more "plate" on the Ram side of the motherboard. So its rectangular..... also it is as long as a Matxboard
The Power connection or connectors is/are on the back of the Motherboard.
The GPU Would be the ASUS Dual GeForce RTX 3060 Ti White OC, DUAL-RTX3060TI-O8GD6X-WHITE, 8GB GDDR6X, HDMI, 3x DP:
 https://www.amazon.com/ASUS-Graphics-DisplayPort-Axial-tech-Technology/dp/B0BRYHR5JY
The CPU/ CPU COOLER is shown in the Video, but of course you can opt to take another one that works with that motherboard.
I have also found a longer assembly video on Blibili if you are interested:
https://www.bilibili.com/video/BV1xX4y167ET/?spm_id_from=333.788.recommend_more_video.13
Now, all of this leaves me with a question: Where can I Buy the case ?
ANYONE PLEASE HELP! XDDDDD LINUS I WILL PAY YOU IF I CAN GET ONE!!!!!!!!
All jokes aside, I really want to build this and a video on this would be lovely...
4 hours ago, Shark77 said:
HI Guys
Just saw this when I just finishing replying to you xD
Do think I should repost same comment again, quick link to take u to the comment ❤️
The store is china based, so in order to make purchase you will most likely have to be in china as they won't ship internationally.
If you really want the case you might have to look into local purchase service that is quite popular in china, where a third party will purchase it for you and mail it over seas.
I might see if I can get one when I go back there soon in June, hopefully they restock in time 🤞
My gosh if this build is nice!!
The mobo and case and gpu are considered to go together, meaning the case is built exactly for that motherboard and gpu.
I'm interested in understanding of there are other ideas/concepts/cases for similar other builds.
