Budget (including currency): CHF 1'100.- ± CHF 200.- for PC, between CHF 250-350.- for Monitor
Country: Switzerland
Games, programs or workloads that it will be used for: Mainly for gaming: Monster Hunter World, Divinity:Original Sin 2, Noita, Dysmantle, Stardew Valley
Other details: https://de.pcpartpicker.com/list/92pcJM
If Possible, i want to play on 1440p at at least 60 fps consistently.
Thank you to everyone that is able to help me with my build!
https://linustechtips.com/topic/1505728-first-pc-build/
Pretty nice little build! If you want to save money, you could drop down to the 5600 non-x variant. The cooler you have is also waaay overkill for the 5600x -and if you're attached to a tower cooler, go ahead and get the thermalright peerless assassin 120 (se) instead, it's a better deal.
https://de.pcpartpicker.com/list/jjPrd9
That's what I'd personally go with - you save a bit of money, all that good stuff. I have less guidance to give on the monitor, but the one you have listed is decent enough. Finally, the motherboard miiiight need a bios update - make sure you have access to an older ryzen cpu to update it if you go for this motherboard.
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930299
DONT PAY FOR WINDOWS
Also for that price you can get a way better PSU (https://cultists.network/140/psu-tier-list/)
there are tons of used 6000 series that I would lean to
Good case Ive got the same one
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930310
Thank you so much for your help!
I decided now to go for an 5600 and take the included AMD Wraith Stealth CPU-Cooler. I took my first one because i didn't saw that it had one included. I also switched to your 650W Power Supply.
I will probably take my first motherboard because im not certain i will have an older ryzen cpu available. But thank you nontheless for your recommendation.
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930515
Thank you so much for your feedback!
I will probably take a look at some used PSU's from where im from.
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930524
ok ope you like your new computer
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930528
I would go with 5700x for this game. I find that game pretty core hungry
Outside of that maybe getting an SSD with a dram cache. They are normally 20-30 euros more
32 GB ram since ram is cheap now, but 16 is still fine for today
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930560
1650CHF, which is 1685EUR at the time of writing. Here you go.
PCPartPicker Part List
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  (€342.96 @ Galaxus)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  (€45.90 @ Amazon Deutschland)
Motherboard: Gigabyte B760 GAMING X DDR4 ATX LGA1700 Motherboard  (€143.33 @ Amazon Deutschland)
Memory: G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€63.90 @ Amazon Deutschland)
Storage: TEAMGROUP MP33 PRO 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (€101.49 @ Computeruniverse)
Video Card: XFX Speedster SWFT 319 Radeon RX 6800 XT 16 GB Video Card  (€579.00 @ Amazon Deutschland)
Case: Deepcool CG560 ATX Mid Tower Case  (€79.90 @ Alza)
Power Supply: Gigabyte P750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€91.75 @ LK-Webservices)
Monitor: AOC Q27G2U/BK 27.0" 2560 x 1440 144 Hz Monitor  (€253.90 @ Alza)
Total: €1702.13
Generated by PCPartPicker 2023-05-08 23:35 CEST+0200
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1505728-first-pc-build/#findComment-15930818
