cpu fan
Go to solution Solved by Poinkachu,
22 minutes ago, Jaedyn s said:
I'm am currently building a computer for the first time after selling my console and as soon as I turned it on for the first time the CPU fan started to make sounds like rocks inside the fan hitting the side i cannot seem to find the problem yet does anybody know whats wrong.
Check if there's any cable / object in the way of the fan blades.
Check if the fan wobbles
https://linustechtips.com/topic/1505726-cpu-fan/
Could you attach a photo of the cooler?
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1505726-cpu-fan/#findComment-15930243
Refresh before you reply
https://linustechtips.com/topic/1505726-cpu-fan/#findComment-15930269
