I bought the RTX 4080 GPU and I’m wondering if I need to upgrade my Ryzen 7 3700x CPU. I use my PC for computer science coursework. I run a couple of virtual machines, and gaming at 2K/144fps. I'm considering the Ryzen 5 5800X3d, Ryzen 9 5900X, or Ryzen 9 5950X CPUs My motherboard doesn't support the AMD 7000 series.
If any of these CPU’s aren’t worth upgrading, should I better off overclocking my CPU? I have a good 360mm AIO cooler.
Thank you.
https://linustechtips.com/topic/1505399-cpu-upgrade-help/
Zen 2 will definitely bottleneck a 4080 in certain scenarios some of the time, that being said, like always, if it does what you want it to do as in performing to your expectations fps wise and programs wise, I wouldn't mess with it. Choosing the right cpu will depend on rather you lean more towards gaming or more towards work related tasks, the 5800X3D will be the fastest gaming wise, but it'll lose ground in work tasks just based on the core count vs the other processors you've listed. I'd use the system as is with the 4080 and see how it performs. If it isn't up to snuff for you then consider your options and what you think will give you the most value for the tasks you mainly do.
As far as overclocking goes, it won't make much of a difference with Zen 2. Zen 2 still had the split CCX design and no amount of clockspeed you'll realistically hit will make a difference worth noting. Zen 2 's weakness is the core to core latency as a result of the split CCX/cache design. Most of the time it isn't a problem but you can run into cases where the latency between cores just limits the maximum amount of performance/frame rate you'll be able to achieve.
Main PC :
CPU = R9 3900X / Motherboard = Asus Crosshair 8 Hero / GPU = EVGA SC Ultra RTX 2060 / RAM = G.Skill 3600 16-19-19-39 ( 32GB / 4x8 ) / Cooling = Dark Rock Pro 4 / Storage = Western Digital Caviar Blue ( X4 ) Crucial 500GB NVME, 500GB 970 EVO/ PSU = Seasonic X-850 Modular / Case = Corsair Carbide 200R
Wireless = Asus PCE-AC56 / Keyboard & Mouse = Corsair K70 MX Blue, Logitech G203 / Headphones = Hyperx Cloud Alpha /
https://linustechtips.com/topic/1505399-cpu-upgrade-help/#findComment-15928193
Ah okay, 5800x3d is basically the best out of the three for gaming. Yet, the core count is going to be the same as the 3700x. So if I want the best of both worlds for core count and the core speed, maybe the 5900x might be the choice? After looking up the 5950x, it’s pretty expensive I found on Amazon for ~$470 compared to the 5900x is ~$325
https://linustechtips.com/topic/1505399-cpu-upgrade-help/#findComment-15928262
i can't recommend the 5900x or 5950x, 5800x3d would be the choice here.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1505399-cpu-upgrade-help/#findComment-15928271
