Hey, ive come across a very weird issue that prevents a new pc build from booting. I got a KEDIERS white pc case that I wanted to use for this build, but i have run into a problem. For the first few hours it ran perfectly fine. no problems what so ever. Mind you, i didnt touch anything since booting from the first time and playing some games, to having to take out the connectors, so nothing was altered. However, the next day, the pc wouldnt boot normally and when i pressed the power button on the case, the cpu led would light up red then dram would light up orange and they would alternate forever with no display. Now, when i took out the front panel connectors (power SW, power led -/+, etc.) and manually jumped it with a screwdriver, it worked flawlessly. Boots without and issue and here i am, writing this on that pc. When i plug in the connectors as they are labeled on the motherboard, the pc goes back to that non booting led flashing phase, and yes, they are all plugged in the right order. What could be the cause of this problem? There isnt a single issue on the pc when its running from being jumped, no overheating, nothing. Could it require a pc case replacement? Thanks
https://linustechtips.com/topic/1505101-front-panel-connector-issues/
