White post led every other day
1 hour ago, jigetuz said:Hello everyone,
four weeks ago i changed the RTX 3070 in my build with an RTX 4070 Ti (Asus Rog OC Edition). On the first boot, it kept being stuck on yellow post led, an issue i was able to resolve by resetting the cmos. After reenabling docp in the bios, everything ran fine.
About ten days ago, when booting up the PC, the display wouldn't turn on, along with any connected hardware (leds in mouse, Keyboard, Wireless hub). LEDs in the case itself went on like normal. I was able to fix the issue by rebooting.
Since then every second or third day, when booting the PC, the same thing will happen. I noticed that the post LED would get stuck on White, indicating an issue with the GPU. However, once i reboot the pc, everything starts normally and the PC and GPU perform without issues (expected performance in games etc, no crashes/bluescreens or anything). The other days, the PC will boot normally on the first try.
I am using following system:
Asus tuf gaming x570-plusRyzen 5800x
32 GB (4x8) DDR 4 G skill 3600 CL 16
be.quiet Straight Power 11 750 W (Titanium rated)
i used a 12VHPWR cable supplied by bequiet to connect the GPU to the PSU.
Does anybody know what the most likely cause for this problem is?
Thanks in advance for any ideas
Flash the latest motherboard Bios.
Flash the latest GPU vBios.
Retry.
