Airflow Problem
Solved by johnno23,
Remove the front panel. Measure exactly where the center of the front fans are.
Now using a marker pen place a dot on the front panel that corresponds to the fans center.
measure you fans are they 120mm or 140mm.
Once done simply take your panel to any shop where they make advertising signs etc.
Most have a CNC machine for cutting durable plastics ABS plexiglass thin aluminum etc.
Ask them if they have time to use the machine to cut holes at the needed size.
once done go home place front panel done and dusted for about 10 Bucks.
If you are good at tinkering you can DIY the holes. Done it myself in the past on cases where the front panel was closed and had only side vents for air intake which was next to useless.
