Mice help
Go to solution Solved by Timme,
Just now, foxcanoe said:
Win guessing deatheradder v3 it is then?
Widely considered the best. If the shapeis to your liking, go for it.
I am having a hard time choosing one of these mice I only want razer recommendations (if it is not razer but an offer I can’t refuse on a well known site with a good seller I will) I have chosen the deathadder v3 pro viper v2 pro and viper 8Khz. Thanks for your help In advance
https://linustechtips.com/topic/1503996-mice-help/
Have you checked any comparison between the 3? (Maybe Razer has some info or comparison on their site)
What are the things you want to do with it?
What are you used to etc.
Put some effort in, and you will see others will go trough great lengths to give you options. 😉
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1503996-mice-help/#findComment-15916947
I check and could I have money by going with the non pro variant and choose the deathadder v3 and viper 8khz I don’t care about it being wired or wireless and don’t care about rgb. I will be using 2.5k-2.75k dpi on the mouse will the 8khz pulling rate be worth it
https://linustechtips.com/topic/1503996-mice-help/#findComment-15916955
Must be the latest iteration? You can get a Viper Ultimate for around 80$ on amazon.com. Also, some people swear by Xtrfy MZ1. And why not consider Basilisk?
From what you've listed, Viper and Deathadder are completely different, and the choice depends on your hands and grip. This site might help you out with the choice.
*using non-conversational, sketch-level language to gesture at structure and direction.
The GB8/12 Liberation Front
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917025
Keyboard razer headset razer mousepad razer and want a razer mouse to prevent a lot of bloatware and rgb can sync if item has it
just buy a bunch of the mice and keep whatever you feel fit your hand and you like the best the mouse is a very personal thing that only you can decide is good or not
I hit 700W on an i5 with a NHD15
Also I'm 14 so please just confirm anything I say with someone more experienced
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917040
Is it just the mouse or the dock is included viper ultimate black mouse only can be gotten for 80 usd on the razer site
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917048
Black mouse without a dock. With the dock, it's 90 for both colors.
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917051
What about the deathadder v3 that seems to have better parts than the viper ultimate and idrc about it being wired or wireless. unless the viper ultimate has incredibly lower latency then the deathadder v3 I’ll get it then
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917056
2 minutes ago, foxcanoe said:
What about the deathadder v3 that seems to have better parts than the viper ultimate and idrc about it being wired or wireless unless one is incredibly lower latency
It is about twice as much with a dock. Regarding the hardware, honestly, both are overkill performance-wise. so there won't be any noticeable difference.
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917062
https://linustechtips.com/topic/1503996-mice-help/#findComment-15917067
