5 minutes ago, Gilgamang said:
I just got a 4080 and it fits in my case, but as you can see, the cables are bending quite a bit. Is this okay? Or is it a dangerous amount?
Mine has been like that since November, no problemo.   Could be the angle of the picture but the right side of the connector does not look like its properly pushed in, take another look at that.  The bend radius is alright in my opinion if the connector is properly seated.
ya this is fine. my 3080 is like this too it's all good aslong as its not pressing so hard the you have a big struggle getting the side panel to go on
Okay thanks for your reply. Does it still look like that from this angle?
That looks alright. Mine look like that too 🙂  Ran a 220mhz+ core OC and +1600mhz memory OC without issues since November!  You can start gaming now 😄
