35 minutes ago, Andy that has problems said:
Hello so i noticed that one of the pins were moved, however… is this normal? https://imgur.com/a/LyuhrUL
it's normal for untrained to ... sometimes trained too, to break stuff.. so yeah.  try bending it back.
if it breaks, you are one port short.. as each row of pins are each own USB port..
https://linustechtips.com/topic/1503312-usb-32-pin-moved/#findComment-15911906
Hello, i’m not really a beginner. However. I put it in the right side and it bent smh. It just wouldnt go in. It went in normally after that one. So it might downgraded tho.  And thank you for saying that. So 1 port = 1 less port? I’m mostly a builder but not knowing what each pin does. It says backwards compatible
https://linustechtips.com/topic/1503312-usb-32-pin-moved/#findComment-15911924
You can try to bend it back but make sure to not bend it the other way. This type of metal, when bent too much or repeatedly, becomes fatigued at the point that it breaks really easily. In any case that's the ID pin from the pinout I can see online and most devices don't use it so it will work for most stuff if you end up breaking it
https://electronics.stackexchange.com/questions/395950/what-to-do-with-usb-3-0-id-pin
ID pin in usb 3.0 header discussion
https://linustechtips.com/topic/1503312-usb-32-pin-moved/#findComment-15912399
