Posted April 25, 2023 Hi guys, I have found a great deal on a LG OLED C1 65 inch and TCL 6r6 75 inch for the same price. Which one should I get? I know the TCL may get brighter but no mini led tv can beat the inky blacks of Oled. At this point I really dont know, and going to the store to look at them doesnt help because of the lights. I don't care about the OS they use cause I always use my apple TV. I watch tv in a dark environment which pushes me towards the LG but the bigger size of the TCL is also appealing. Helpppppp I willl choose whatever the majority chooses LG C1 Screen size: 65 inches Resolution: 3,840 x 2,160 HDR: Dolby Vision, HDR10, HLG Refresh rate: 120 Hz Ports: 4 HDMI 2.1 (1 with eARC), 3 USB Smart TV software: webOS G-sync and Free-sync TCL R646 Screen size: 75 nches Resolution: 3,840x2,160 HDR: HDR10, HDR10+, HLG, Dolby Vision Refresh Rate: 144 Hz Ports: 4 HDMI, 1 USB Audio: 2 (10+10) Smart TV Software: Roku TV Free sync Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 25, 2023 Is the C1 new? Weird to see a new 65in one in the wild. I would personally never buy a used OLED, if so. If it is, compared to that TCL, I'm buying it every time. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 25, 2023 Author The C1 is not new, but I am allowed to make test to make sure there is no burning Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 26, 2023 I voted LG. Even if it is used, as long as there is no sign of burn-in I'd rather have the OLED. But a factor in this is view distance. Depending on how far you sit from the screen, the size of a 75" may end up being a better choice. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted April 26, 2023 What is viewing distance? The lg oled is by far the better quality television. If you go this way. Don't sit further than 8 feet or so. Up to 5 feet is the closest distance you want without moving your head. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
