How do I mirror (reverse) my display?
Solved by BobVonBob,
I'd check the settings on your projector. The setting might be named something like "rear projection", "invert", or "flip". If there isn't an option for something like that, UltraMon can flip the screen or an application. However, it costs $40 USD.
Edit: If the projector doesn't have horizontal mirroring but it does have vertical mirroring for ceiling mounting you could turn that on and rotate the display by 180 degrees in Windows. It's jank but it will effectively result in a horizontally mirrored screen.
